Anyone running 18" Fikse's on a 930?
Am thinking of either 17" Fuchs or 18" Fikse. Anyone have some pics to see what it looks like? Any comments, good or bad?
Thanks jack |
what model of fikse wheel?
Any model. Just want to see what they look like. If they look to large for the car, etc.
Thanks |
Here's a couple pix of my 930 with Fikse FM/10's. They are 17's and the fronts are 8" with a +30 MM offset and the rears are 10" with the same offset. The finish is black anodized centers with polished outer rims. I hope this helps.
Roger B. ![]()
FUSHIGI
fullquack ran 17' fronts and 18" rears...they look really nice!
I have 17's for my 930, but the car is still in the build stage.
Forte500
18" X 235 in front and 18" X 315 in rear. Kinesis rims but very similar. Perfect size IMHO for 930.
Dixie Boost Hooligan
IMHO and Fwiw; 18's most often look disproportionate on a 930. Suspension set up requires compromise to avoid an overly harsh ride if still running t-bars.
72 911 T 3.0 / 73 911 3.0 turbo 74 BMW 2002 TI 79 930 / 84 911 Turbo / 2010 Cayenne GTS 87 911 Carrera Coupe / 87 911 Turbo 94 911 Turbo 3.6 /17 911 Turbo / 18 GT3 / 22 GT3 |
![]() ![]() 18" Fikse's 245's up front 295's rear. Top pic is at stock ride height. Bottom pick is after lowering. Hate putting the 17"s back on for storage and early spring driving!! |
Yep, been running Fikse 5S's 17" fronts, 18" rears for 2-1/2 years. 255 fronts, 295 rears B.F. Goodrich KDW's.
The ride is NOT harsh at all{stiff yes}, as others here have eluded to. I'm running 23mm & 30mm T-Bars & 22mm adj. sways, Bilstien HD shocks on all 4 corners, Rebel racing front control arm bushings & rear spring plate bushing. The car is very low{2-1/2" clearance under the front valance}, almost Identical ride height as the other beautiful black ride shown earlier in this thread, from BSKI. And Black is the fastest color....... ![]() Mark
R.I.P.
I think you ment White is the fastest color
![]() 17x9 front 235's 17x11 rear 315's kind of want 18's now..
18 RH 235f/295r.
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud |
I'm seeing some nice looking combinations. The 18s look pretty good. Thought they might look too big, but I don't think so. Please keep sending pics. Thanks alot guys.
River Rat
9x17 w/255's 11x17 w/315's No issues with tires hitting body.
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs. |
Fikse Profil 13 in my modified 930. 18" x 11" rear, 18" x 9" front. Very lightweight, very strong: I recommend. Only great experiences of quality: they don't easily change shape even if driving hard through track kerb bumps.
Garage: Strosek911 RUF BTR|Strosek911 3.6 rat RSR|Strosek 928SR|928S4R|928S|996C2RSR|Cayenne Offroad ...and more... Altogether 15 Germans - 2 Italians - 2 British |
Fikse FM-10 8,5x17 and 10x17
Trond R. 1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc.. 1972 914-6 GT replica project 1986 944 Turbo |
I agree with turbo3six-18's look like a cartoon car.
Personally I like the look of the 18's, I guess it's a matter or preference.
Seeing a nice 18 with the top a little tucked under the wheel well is a nice look, but that is my opinion. I have 17's so once I can get the engine back in the car and it back on the ground, I will post up some pictures. |
Actual Profil13 under my other 911
