Help with wiring 930 Relays on a transplant
I am working on cleaning up the wiring in my 1972t with a 1986 930 motor in it and I need help with the right wiring fir the relay panel/fuel relays. Does anyone have pictures abc or or diagrams to help? Here's what I have to deal with
The rear relay I'm removing since it's for the rear defogger, the other two I need to see how to wire them, most wires are cut??
Better view of the wiring on the relays, I also need to figure out how to put th overboost sensor back in the loop for the fuel pump
Is this the correct wiring points for the relays?
I noticed there aren't any fuel pumps on your schematic. ?
Steve 86 930 91 535i 73 TR6 |
The other schematics I'm using
And this one too
Great, thanks. PO by passed relay G in my car. I'm gonna put it back as my pumps run all the time when the ignition is on.
put heat shrink on those bare soldered wires,
I would also solder any crimped wires, I use the bare connectors with a little solder then heat shrink over the connector,
I'm redoing all the connections with solder and heat shrink, and trying to get rid of any wires no longer needed.
Does anyone have a hi-res of this image? Or PDF?
I would like a copy of that image too. I'm building my data base for when I rewire the car. That will not be an enjoyable task.
James 1989 Slate Grey 930...sold ![]() Looking for the next one! |
