Tial 46mm WG .8 bar
Quick question.
Installing the Tail I picked up from Brian. It's a 1. bar wg. I opened it up and just want to confirm which spring to remove to make it the stock .8 bar. It's the smaller spring that sits inside the later red spring I want to remove right?
Thanks in advance!
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C
Old 09-29-2016, 04:00 PM
Mr9146's Avatar
Here you go:
Old 09-29-2016, 04:05 PM
Thanks! Removed the little spring to run .7 bar since the larger spring is red and that's stock boost on a 930 after a little more research!
Old 09-29-2016, 04:26 PM
