suddenly super rich and high idle
Fired up the 930 last evening, the engine idled at 2000rpm and AFR's in the low 10's. Never one to retreat I stalled it only once in an intersection, made a quick direction change and luckily had to push it only 30 feet or so into a conveniently open park spot. The ensuing warm start was difficult, pinching the AAR valve to IC hose did bring the idle down. Any immediate thoughts? Fired right up today but still high idle, drove with a clamp on the hose to bring rpm down but any throttle that produces any level of boost bogs it right down with super low afr. (stall, push, repeat...) I don't even tell people why I'm 20 minutes late anymore although the heavy exhaust odor is pretty much a dead giveaway...
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud Last edited by slyguy; 10-13-2016 at 04:17 PM.. |
Sounds like an intake leak to me. Check injector blocks and boost hoses first.
1988 930 Venetian Blue |
If the rear fuel pump is not getting power the CIS warmup devices aren't either and the symptoms are similar to yours. Could be rear fuel pump relay.
I would say the the wur and the aav is not getting the power, thus it is working in cold start phase.
first place I would start.
Now we're talking. Definitely seems like an on/off situation, I pulled the connectors to both plugs while it was running high idle and neither one had any effect on the idle. Thanks for the starters, back at it this afternoon. Tom
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud |
Ha ....... Your title described a buddy of mine who won the lottery
you need to check power at the connectors
Mighty Meatlocker Turbo
Or first just switch out the appropriate fuel pump relay, as Jim suggested in post #3, and see if running is back to normal (since rear pump relay also supplies power to WUR and AAV). |
If the wur and the aav is not getting the power, it wont make any difference if You remove the plug or not. Measure the current between the two legs of the connector (wiring side). There should be 12+ volts.
Rawknees, I'd say it was just a little loose in the socket and not quite touching the sides.
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud Last edited by slyguy; 10-14-2016 at 01:22 PM.. |
PS- Mr. SlobberingSlyGuy, those knee pads look like they have been busy up yer way (not that there's anything wrong wiff dat')!!!
thought I had it buried
