-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   has anyone run tunerstudio with linux and usb cable? (http://forums.pelicanparts.com/showthread.php?t=933258)
smurfbus 10-23-2016 09:43 AM
I have spent last 8 hours trying to get it working, no luck.
Detect does not find anything and tunerstudio works fine with my older xp laptop. I would really like to get it to function on my faster lenovo x201 with linux mint with newest kernel and packets. I can get the ftdi2xx drivers to read from the ms3pro but the ms3pro does not like to connect? Not much info on this over intardnet. First 7 hours went before I could even figure how to get the ftdi2xx working (need to rmmod VCP drivers first)
I'm a total linux noob too, but I can follow instructions and that's how I got the drivers to function. I also needed to install some compiling packets to get it working but those were easy to diagnose with error codes like 'missing stdio.h'
http://forums.pelicanparts.com/uploa...1477240811.gif
Any help appreciated.
Black_Hat 10-23-2016 09:46 AM
version of linux , Ubuntu ?
Black_Hat 10-23-2016 09:52 AM
doh ..just saw linux mint
smurfbus 10-23-2016 09:54 AM
Here the shot from usb ms3pro eeprom read
http://forums.pelicanparts.com/uploa...1477241646.gif
Black_Hat 10-23-2016 09:55 AM
linux mint is based on Ubuntu , try searching the Ubuntu forums or knowledge base
Black_Hat 10-23-2016 09:58 AM
the Ms3pro does not like something the Linux is doing
some debug here for USB mounting ect
https://help.ubuntu.com/community/Mount/USB
smurfbus 10-23-2016 10:04 AM
Does the ms3pro show as a flash as it has sd-card in it? So mounting problem perhaps?
I installed a hardinfo app and it does not show any com ports or usb devises?
I need to look at your link, thanks
Black_Hat 10-23-2016 10:26 AM
sorry I thought the noncom was between your laptop/tablet and the MS3pro
smurfbus 10-23-2016 10:37 AM
Well it is but only from ms3pro to laptop it seems as I can read the eeprom of the ms3pro from my laptop (at least I think it did that in the second post)
F1 will start soon so cant focus on this much longer today
Black_Hat 10-23-2016 10:43 AM
Ha
I'm in Austin at F1 track at decent Corporate booth on front straight
nice 75 degrees F wind is picking up and will have some impact
smurfbus 10-23-2016 10:51 AM
Ive done Monza twice, hockenheim, san marino ( Imola) and hungary. The sound was a big downgrade so I havent gone back in few years.
I will of cource root for Kimi and Valtteri but strangely enough Nico also has a Finnish passport ( being Kekes son)
Black_Hat 10-23-2016 10:58 AM
I'm disappointed F1 has turned in to tire mgmt instead of who can drive the fastest
flightlead404 10-23-2016 11:13 AM
I went through this trying to run on linux and mac native. I've ended up running a windows 7 vm under vmware fusion on my mac. it also worked under virtualbox on ubuntu.
I had to find ancient drivers for my usb to serial converter, but it works now.
smurfbus 10-23-2016 11:28 AM
It did not work on my linux wine install either.
flightlead404 10-23-2016 12:03 PM
Forget about wine, get virtualbox
jpnovak 10-23-2016 04:48 PM
I don't think it will work. Probably need a direct serial conversion.
You could also consider MegaTuniX but I think development stopped on it.
https://sourceforge.net/projects/megatunix/
smurfbus 10-23-2016 09:05 PM
Huh, I think I will need to look at the virtualbox or is that also waste of time? My x201 has win7 lisence at the bottom. Is there win7 media available or do I need to find one that came with some laptop? IIRC xp did not install on it with some blue screens from some PCI driver.
smurfbus 10-25-2016 10:48 AM
I intalled a virtualbox win7 but it does not work as the usb cable does not get recognized and I cant install the drivers.
BUT
ms3pro support helped with this and now I have connection with MINT (they have a test install on MINT). I needed to run tunerstudio from terminal with sudo so its a permission problem anyway. I hope to get the correct group info so I can run it also from icon but this was a major brakethrough.
My account permissions so far (non working)
http://forums.pelicanparts.com/uploa...1477417699.gif
JFairman 10-29-2016 10:37 PM
You may be able to run it in windows XP compatibility mode on any windows 7, 8.1, or 10 machine. Running native or as a virtual operating system using the virtual box program in flavor of the month Linux or MAC.
Takes about 15 seconds to find out.
smurfbus 10-29-2016 11:07 PM
I installed a virtualbox and win7 on it. Could not get the usb or com ports to work with ms3pro. Now that I got my ftdi2xx drivers to work from linux terminal I will use that. Virtualbox was also much slower than native linux, painfully slow I might add.
I just bought a expresscard rs232 unit with oxford 952 chipset for my lenovo and hopefylly I can get it to work on linux too. It has native serial PCI communication so it should take out all possible communication errors that are trouble some with rs232/usb adapters. That would also take care of using hex-com vcds with my audi.
