AFR's at idle
What AFR's do your well idling 930's have ? Just setting up mine and wondered what's optimum ?
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
I thought it was the same as any other car 14.6 at idle.
yeah, I know that's theoretically correct. Just checking where everyone else's is happy
Crotchety Old Bastard
Typical target is 13.0:1 to 13.5:1 AFR at idle for stock cams, 12.5-13.0:1 for SC/964 cams. This should result in ~14.5:1 at cruise.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
With CIS anyway...is EFI any different?
Steve 1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters. |
PorscheMoparLiterbike
If your CIS Kjet is lambda/stock then will get to 14.7ish when warmed up and transitioned to closed loop control
From Charles Probst Bosch book "because lambda sensor operation depends on high temperature the system operates open loop before the sensor warms up. this can cause driveability problems and increased exhaust emissions do too imprecise mixture control. To correct this many cars have a lambda thermal switch located in the coolant or on the cylinder head of air cooled Porsches to give the control unit an additional input and ensure proper fuel metering during engine warm up. When the engine is cold the thermal switch is closed the control unit send a fixed slightly rich duty cycle signal of 60 percent to the lambda control valve. When the thermal switch warm enough to open the control unit sense of fixed middle signal 50 percent duty cycle. when the lambda sensor reaches operating temperature so it signals are valid the control unit switches to closed loop operation. Remember in closed loop the duty cycle signals are constantly changing cycling back and forth between about 45 percent and 55 percent so that the air fuel ratio is maintained near stoichiometric - lambda equals 1."
88 930 BnB Kinesis tial 1bar k27/29, Turbokraft IC+blocks+rokr loks+ ported intake,edelweiss cams, KEP/Sachs, Verden Tool 38mm PP heads, ARP bolts/studs, twin plug for future |
Stoichiometric 14.6 for most of our cars seems too lean. When I had an AFR meter, mine idled best at around 13.5 if I recall. I ran (and still do) without the lambda circuit, i.e., O2 sensor unplugged/open loop.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
Cold idle around 13, warm around 15, cruising 14.5 and full boost less than 10... happy engine
I thought full boost should be between 11.0 and 12.0 afr? Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her! |
Agree Mark ...I'll start driving easy after partial warmup before CIS goes into closed loop and AFR's in 12ish range - idle is 13's --just to 2500rpm start stop, cruising and it runs stronger
not sure of CIS configuration of OP. Just adding to discussion from some past posts i was involved in. Also your comment got me tinkin - before my rebuild 930 was my daily for a year or so and i had a lot of highway travel - kept lambda control and got decent highway mpg...... i might just unplug and run open loop with FV at default duty cycle and further improve NA operation until i figure out my WOT problem. Sorry to hijack
Well since my Lambda apparently pooped the bed.. it's unplugged so I'll be setting it up that way.. Thanks!!
I took the advice of the experts here when I was tuning it after a bunch of upgrades and let the car tell me when it was happy. I'm at about 13.5 at idle with no lambda and stock cams because that's where it idled best. I'm a little higher at cruise and on full boost it drops to about 11 or 11.5 or so. Below 10 on boost it was painfully rich and it wasn't happy. Point is that while we should start with a common baseline, every car runs a bit different and you should tweak it from there to make yours run its best.
1988 930 Venetian Blue |
13.5 is about right for mine with stock 3.3, sc cams, longneck ic
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! |
Each engine is a bit different - depending on mods and wear in engine. Worn engines prefer a bit more fuel. I set mine where the idle is most happy - irrespective of numbers. Rather than target a number. Mine seems happiest around 12-12.5. It has very little effect on your running AFRs - except maybe a slight effect on low throttle running. 13.0 is def unhappy for me.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Turbofrog
Mine Idles happy on about any AFR? Whitch afr should bring best emission values for MOT onE98 (93)? Last time I was on E85 and around 14.7AFR and had trouble passing the emissions test? This time I will go with E98 (US 93). I remember we had to put a rag on the other muffler exit so possibly it was too much oxygen in the tester as hc limits are high for old cars and mine does not even need cat.
************************************************** ******************************* 10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg |
Mine was happiest @ 3.0% CO at idle with CIS & SC cams. It seemed to idle fine with lower, but that could cause hesitation tipping-in off-idle, and sometimes a lean surge on light cruise.
Twin-plugged with sequential injection, idles fine @ 1.0, 1.05 lambda on E10.
'77 S with '78 930 power and a few other things. |
My car always seems good at 14.5-7 at idle 14.5 at cruise and it hits 12.5 at 1bar on the money every time. Pulls pretty clean throughout without hiccups even down low. Modified CIS system and twin plug though.
3.4,K27,Andial IC,Sc cams,Ported heads,Electromotive Ign,Twin plug,Leask Wur,RarlyL8 zork,GHL headers,Simplified CIS,Ported fuel head,Fikse wheels,Etc.Go hard or go home |
got it all ironed out!! running and starting great at about 13.5 ... Thanks!!
Metal Guru
The Service manual for my '91 states 3.0% CO.
With tolerances, this charts out to 13.7 - 14.1 afr. My car idles fine at this setting, even with SC cams so I called it good.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
interesting, I think I'm at 13.1 to 13.4, Euro 1985 W/O o2 control loop
there may be a difference between what models with o2 feedback loop like VS what those without like such as Euro models.
David 1985 Black 930, K27 7006, Garretson Intercooler, Adj boost, TB: 23 - 31mm, bielstein sport shocks, ER polybronze bushings front and rear, ER monoball joints front and rear with offset camber plates, 935 X triangulated strut brace, raised spindles, racing bump steer kit 1981 Black 911sc (sold) Last edited by Roby466; 07-24-2020 at 10:20 AM.. |
