-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   1976 930 turbo K27 problem (http://forums.pelicanparts.com/showthread.php?t=941304)
sleepersd 01-03-2017 07:30 PM
Im restoring 76 930turbo and i found out today that my original k27 turbo can not be rebuild.
Probably I'll have to buy new one, should I go with a same one or to get something else?
turbo owner 01-03-2017 07:50 PM
K27 is not origional for your car
sleepersd 01-03-2017 07:53 PM
Or maybe my guy told me that k27 is the one that i should buy it, not sure now.
So what is original one and what should i get for my now?
flightlead404 01-03-2017 08:05 PM
Were there not some Euro models that had a K27 as original?
I just removed a K27 from my car that has a 930 part number and the outlet of side of the turbine side is the same as the 3LDZ that US cars had and fits the stock intercooler without any adapters etc.
Its for sale too :-)
sleepersd 01-03-2017 08:35 PM
My car is euro model
Do you have K27 or 3LDZ?
JacobS911 01-03-2017 09:24 PM
Post up a picture of the turbo.. that will help! 3ldz can be rebuilt. I just had my k27 rebuilt by Charlie @Evergreen turbo out of florida. He did an incredible job on it and I highly recommend him. Talking on the phone he says he's able to rebuild the 3ldz as well as I was curious about my old turbo and some of the rumors of it being a pain or difficult to rebuild.
Tom F2 01-04-2017 02:14 AM
Your car came with a 3LDZ. The K27-7200 is, I believe, the current production replacement for the 3LDZ, which is no longer manufactured. The K27 is better, but it's not a perfect fit. You'll have to modify the sheet metal housing over the turbo, and the inlet pipe will not exactly line up, but it's pretty close. Rebuilding your 3LDZ is the simplest solution.
RarlyL8 01-04-2017 04:51 AM
The K27-7200 11/11 was the OEM turbo for the 964T. The 3.0L 930 had no options, only the 3LDZ as standard. Further, the '75-'77 3LDZ does not have the outlet boss with O-ring configuration found in the 3.3L intercooled 930s making the K27 an easier retrofit than in the later models.
If performance is the goal then the 3LDZ goes on the shelf. They are not hard to rebuild but there is a rash of Asian bull**** parts on the market that immediately fail so make sure you find a KKK/BW specialist that uses genuine German parts.
flightlead404 01-04-2017 06:53 AM
I have removed a K27 that has a normal Porsche outlet side and installed a K27 with the more typical shortie side that would need an adapter for a stock intercooler but fits a long neck just fine.
Here's a pic of the data plate. Its a bit dirty, cam oil line leaking all over it pretty bad. I can clean it up and take some pics. Its got about 20k miles on it and is not leaking/smoking, worked perfectly when removed.http://forums.pelicanparts.com/uploa...1483541582.JPG
stevie 77 930 01-04-2017 09:05 AM
Not sure if Brian (RarlyL8) still offers this, but I had him rebuild and "modify" a 3LDZ a few years ago. No install issues and still going strong
RarlyL8 01-04-2017 02:48 PM
Unfortunately not, the bad Asian knock-off parts killed that mod. They were mixed in with KKK/BW parts causing chaos. They got it sorted out but too late.
JFairman 01-04-2017 03:41 PM
Durabilt Turbo will fix it quickly. They are where the Porsche IMSA race teams go.
They install a 360 degree thrust bearing upgrade and will make parts if they are no longer available new from 3K Borg Warner.
Durabilt-Turbo.com - www.durabilt-turbo.com
sleepersd 01-04-2017 05:41 PM
So for how much you selling it?
My mechanic told me ,that shop where he has sent mine called him and they said that my original turbo is to damaged and they cant rebuild it.So ill have to get another one
sleepersd 01-04-2017 05:47 PM
I dont have a picture,my mechanic sent it to the shop to be rebuild alredy but turbo is to damaged and cant be rebuild.
sleepersd 01-04-2017 06:11 PM
Link doesnt work,actually their web is down
RarlyL8 01-04-2017 06:12 PM
I've got a rebuilt 3LDZ and a new K27-7200 on the shelf, shoot me an email if interested. Make sure you get your turbo back, if it is the 3LDZ you want that original part as it has the date stamped on the housing.
sleepersd 01-04-2017 06:14 PM
So your suggestion is K27?
sleepersd 01-04-2017 06:24 PM
I just sent you email
flightlead404 01-05-2017 08:36 AM
Whats the diff between a new K27-7200 and a K27/29 hybrid?
RarlyL8 01-05-2017 10:37 AM
K27/K29 hybrid starts out as a new K27-7200. The 7200 frame is retained, a K29 hot side is bolted on and modified turbine wheel installed. Some machine work required. Result is a faster spooling K29. Fairly expensive but has a niche with Porshe purists and those who want a close to bolt on solution for the 930. Very robust turbo.
