Water vapor coming out of tailpipe
Just wondering if i should be concerned?? Every time i start the car up, it spits water vapor out of the tailpipe. I also just drained my oil catch can, and there appears to be a water like substance, or something that smells like rubbing alcohol. I have never drained ANY oil out of it, just this alcohol like substance. FYI, i am running E85 fuel. Dont know if that makes any difference. Also, I am gravity draining the Turbo oil return line straight into the sump, and no issues with backed up oil.
Mighty Meatlocker Turbo
That's 100% normal - condensation created during rapid temperature change (water pulled out of the air).
![]() Mine does it too
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C |
Now as far as what I hear is fired out of Paul's tailpipe, that's definitely not normal!!!
water vapor H2O is a byproduct of combustion. Hydrocarbons combine with Oxygen, and some of the result it water. The cold weather condenses this in your muffler and it comes out as liquid.
Maybe you should check that the cooling system isn't leaking into the combustion chamber...
Hey Icyhottness, I hear you are an expert tail pipe ANALyzer - true!?!?
You betcha, bisch!! ![]()
Ha ha - awesome!
that's why exhaust systems rust out, especially when cars are driven short distances. they don't have enough time to burn off the moisture and they rust.
Chain fence eating turbo
Here you go, Tippy.......
^^^^ HAHA, poor bike!
Kessel run in 12 parsecs!
Are you sure its not you vaping?
![]() ![]() Dude its perfectly normal, your cats are a workin' cornverimifacatin' nasty ol' carbon to happy time "clizean aire"![]()
Getting old sucks, bring back the good old days, this new stuff is for the birds.. |
At least those ol' biddies aren't vaping from the Blazing Saddles dude's tailpipe!!!! ![]() How about now?!?!
Phew, thanks
I like those better, too, Tippy!! I just wanted to post my pic, quickly, and just happened to see my picture over on the Off Topic forum, where I copied it and brought it over here. Hey, though, I wouldn't mind a fivesome wit dat doe! |
IcyHottStuff, don't get upset just because I have better taste
in tailpipe than you do, bro!!!PS - I own you!!!!! Last edited by Rawknees'Turbo; 02-08-2017 at 01:49 PM.. |
Hey, it was 2:00 am and the bar was closing...Those four had to do!!
I wouldn't kick them out of my sleeping bag!
