964 cylinder on 930
Hello folks,
Starting to make plan for the rebuilt of my 930 engine but been infected by the "while you're at it" disease...
Among other modifications, I'm willing to increase displacement.
For that matter I'm checking few options on the bore side of the equation (stroke may be also modified by GT3 crank).
- Mahle 98mm P&C
- Nickies
- 964 early cylinders machined to fit 930 stud spacing (and spigot)
Does anybody ever did the 964 cylinder modification or heard about it?
Old 05-10-2017, 11:24 PM
I think it should be possible to mill/drill such oval holes by a machine shop. I beleive those are some type of mahle cylinders but not sure
Old 05-11-2017, 02:48 AM
Chain fence eating turbo
Oooh, that's some end mill deflection to mill that deep. Good things it's aluminum
Old 05-11-2017, 05:43 AM
Thanks for the picture, looks like it's been done...
I'm thinking of using early style cylinder to avoid to interfere with the sealing.
Trying to figure out how to machine the holes at the moment... tiny boring bar in lathe, broaching, EDM...
Old 05-11-2017, 08:23 AM
JJK78-951's Avatar
If you are machining them to fit it does not matter which cylinders you use early vs. late.
$.02
J
John~
2003 996 Turbo... 128K Daily-ish
2000 Accord V6... 275K - 65K motor/trans now given new life!
Old 05-11-2017, 09:07 AM
Also need a spacer on the bottom of the cylinder.
Old 05-11-2017, 09:32 AM
TurboKraft's Avatar
Not saying it hasn't been done before, but that doesn't look like a good idea to me. You're milling into the cylinder to tighten up the bolt pattern, and reducing the cylinder wall thickness -- on a boosted engine.
Just buy the correct 98mm slip in cylinders and be done, make your life easy.
If you want to stroke the engine with a GT3 crank, that introduces a whole other level of complexity because now you're adding rods and custom pistons with a revised wrist pin height.
We build a lot of these, give a call or PM to discuss.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 05-11-2017, 10:25 AM
