-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   Window regulator relay ? (http://forums.pelicanparts.com/showthread.php?t=950005)
S1000RR 03-19-2017 06:14 AM
Is there a relay for the power windows, and if so, where is it? Can't find it on any diagrams. Both windows fail intermittently and fuse is good.
Ken911 03-19-2017 06:23 AM
usually ends up being melted switches. especially the one for the passenger side window in the drivers door
S1000RR 03-19-2017 07:53 AM
Looked closer this morning and there is not 12 volts at either side of fuse 1, which controls the sunroof and windows, both of which are not working today. So a little progress.
when I disconnect the black wire at the top of fuse 1, and then jumper fuse 1 from fuse 2, both windows and and the sunroof work fine.
S1000RR 03-19-2017 11:57 AM
Tracked down the relay.http://forums.pelicanparts.com/uploa...1489949845.jpg
