-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   starter issue? (http://forums.pelicanparts.com/showthread.php?t=963080)
Alan L 07-17-2017 03:18 PM
Originally Posted by krasuskyp (Post 9665138)
thanks Alan - dumb question... is there supposed to be a crush washer under that fitting? I'd 'thought' it was a ball / compression fitting?
If we are talking about the same fitting - the big oil union that screws into the lower engine case - your driver side, yes, it is a crush washer - just crawled under mine to check (is on trailer). So, I would first try and verify which bit is leaking - no point pulling apart a good seal. at worst you could wipe the area down with brake kleen, and run it briefly and check to see where the drip forms - on the case, or on the union.
Regards
Alan
jjeffries 07-17-2017 07:19 PM
I had my Rob Siegel European Electrics manual ready to crack open to the alternator chapter but went for the easy stuff first; lo and behold, a loose nut on the chassis ground strap. Big roadblock for electrons. Paul swung the geardrive 13mm wrench so he could say he fixed it. I was grateful we didn't have to pull the alternator. John.
93097004xx 07-25-2017 11:54 AM
starter issue?
My starter ring was so chewed up it was unserviceable. We got a new flywheel starter ring from porsche. I wanted a new starter but my mechanic said the starter was a ok. After reading this thread I'm wondering if the alternator is a persistent issue on some 930s. My starter ring has now been replaced twice in and my 930 has 51,000 miles..
93097004xx 07-25-2017 12:02 PM
I also need to replace my 12 year old optima red top battery. It's still going strong though..
