camdon's Avatar
245 rear tires on an 8" wheel vs a 9" wheel help
Would a 9" wheel make the 245 much wider than an 8" rear wheel?
Old 09-15-2017, 04:57 PM
Sidewall to sidewall distance will increase so more of the outer edges of the tread will contact the road. That results in a little bit wider contact patch.
If you're taking corners fast you should notice a little more grip with good tires.
Only downside i can think of is bigger tires cost more and steering becomes a little harder while parking
Old 09-15-2017, 06:03 PM
Crotchety Old Bastard
RarlyL8's Avatar
Yes the 9" wheel will fill out and look better/fatter than the 8" wheel. That is the combo I have on the front of my 930.
Old 09-15-2017, 06:34 PM
camdon's Avatar
Thanks guys
You have 245 on the front?
Old 09-15-2017, 07:31 PM
Nothing else changed.. they'll look around a 1/4 to 3/8" wider depending on tire brand.
Old 09-15-2017, 07:52 PM
RarlyL8's Avatar
Yes I run 245/45-16 on Fuchs 9x16 in the front.
Old 09-18-2017, 10:33 AM
E-85 sippin drunk
turbobrat930's Avatar
I run a 245/30-18 on a 9.5" wide wheel on the front of my 930
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 09-18-2017, 11:09 AM
I also run a 245 on 9" rims in the front of my 930. 245x45x17 on Ruf speedlines.
1986 Ruf 930
2015 991 GTS-MT
2006 993 S-MT (Gone)
1969 911 T (Gone)
Old 09-18-2017, 12:49 PM
