Turbo Blanket
Anyone using a turbo blanket on their 930 w/ Garrett GT35? If so, results, and which one are you using?
Thanks in advance.
1986 Ruf 930 2015 991 GTS-MT 2006 993 S-MT (Gone) 1969 911 T (Gone) |
Get the TurboKraft heat shielding. None of the blankets hold up from what I have read.
Sent from my iPhone while Driving
Derrick |
I also think it cokes up the oil.
Sent from my SM-N910T using Tapatalk |
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Chris do you make these for the K-27?
- 86 Porsche 930 - Mr.Hyde - 86 BMW 635CSi - Dr.Jeykell - 2006 Infiniti M45 Sport https://medium.com/@crashingdoor |
No, we do not. Never had any requests.
E-85 sippin drunk
To all involved. I would HIGHLY suggest that you go with the TK heat shield, instead of a turbo blanket. I had the GT35r dual BB CHRA and the TiAL cast S.S. housing on my turbo.
I had about 20K miles on my turbo, when the CHRA locked up. I was also NOT using any water cooling, and left the water jacket ports open. I do not know if the blanket itself caused the overheating, the lack of watercooling, or the combination of the two. Safe to say, the CHRA's ceramic BB's over heated, and failed. Thank God it was a low speed (no Boost) failure, and not into boost when it let go. I have since added a closed loop H2O cooling system to my car, and it is CRAZY just how much heat is pulled off of the CHRA after shutdown. I added all this stuff when I went to the new GTX3584RS turbo.
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
Work in Progress
I'm another happy customer with the Turbokraft heat shield. I had to modify mine a little to fit over a Borg Warner S362 turbo, but it did so perfectly fine.
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 |
chris,
when I got my car I was trying to come up with a design that could scoop the air under the car and force more air up and around the turbo. just a thought. I will take an EFI system for my idea
What hot side housing are you using?
-Jayson 1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85) IG: Signature_911 |
Chain fence eating turbo
Sorry to hijack, OP! Hello Jayson, How do you like the BW S360??
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
Definitely agree with Kevin930 that the heat shield is a problem for oil coking, particularly after engine shut down. I'm always careful to drive low throttle for a minute or so before shutting the motor down. I know the heatshield is good for keeping heat away from the motor and fender but also aggravates the oil coking by keeping heat in the turbine housing by restricting the free convection you naturally get. I have put air flow vents in the lower valence piece to help air flow while moving but probably do little when the car is stopped Even without a heat shield I've been thinking about a water jacket and so would like to see how you guys setup H20 cooling system. I have a precision turbo double BB and have not had any problems yet but think it is a problem waiting to happen
Work in Progress
So I'll admit to not being an expert on choosing hot side housings. When I decided my order of importance went:
1. T3 Housing (I didn't want to convert my headers to T4) 2. I was shooting for lower boost threshold and not aiming for all-out peak horsepower. 3. Divided Housing (I thought it would work towards achieving #2) So looking at the options I saw this t3 divided housing on AGP's site: https://agpturbo.com/2nd-gen-cummins-t3-divided-inlet-hx40-outlet-14cm-for-s300/ I cant give a full review of how good or bad it is yet, as I have not had my car up to full boost yet. I just passed the 500 mile mark on a full engine build and only ran 0.5 bar of boost on the car so far. I was not entirely impressed with low end response, but that may be due to my running low levels of boost?? If you or anyone else has any input on choosing a better hot side I'm all ears. (apologies for any thread hijacking)
Yes, sorry OP about hijacking!
I have yet to try it out yet, I'm in the final stages of the build. Just got the engine tin modification done and next up is the bracket for the turbo and I'll be off to the dyno! Pretty excited for it, I worked directly with an engineer at BW to help select the correct turbo configuration for my power goals and target boost levels, so fingers crossed everything works out!
We have the stainless heat shield spaced off the turbine housing slightly so there is an air gap. That's enough to minimize heat transfer. The rear bumper is cooler to the tough with a heat shield installed. I don't think I'd want to have an air scoop and force additional cooling air into the gap. Anything that cools the turbine housing down more doesn't sound like a good thing as I believe it would reduce performance.
E-85 sippin drunk
That being said, the turbine is not what needs to be cooled, the CHRA does. Especially after shutdown. TK's heat shield would be the proper way to shield against radiant heat, without having the risk of overheating the CHRA, especially, since our older cars lack the liquid cooling. I will post a thread about the setup (water cooling setup) that I came up with that works awesome. Will try to get to it in the next couple of days.
Turbo blanket cliff notes:
Pros: 1. Lowers boost threshold 2. Reduces radiant heat around it including cartridge and compressor Cons: 1. Destroys turbine side of turbo It's a catch 22...
If you're sponsored by a turbo manufacturer, by all means, wrap it up!
![]() If you are not, avoid like the plague and get the heatshield from TK.
Thanks guys. I have found this very informational. If I move forward it will be with the TurboKraft solution. What is CHRA?
E-85 sippin drunk
CHRA = Center Housing Rotating Assembly Basically its the cast iron center section of the turbo, bearings, shaft, and wheels.
