need some guidance getting a previously running 930 back on the road
Hi all,
This is actually my first time ever being on the forum, and, outside of doing oil changes for my dad's 930 and some work on his 944, this will be my first time working on a Porsche. Long story short, my dad has a 930 slantnose that was involved in a cosmetic accident, and has sat since (10+ years). It was running fine before the accident, but due to lack of time and circumstances, he was never able to find time to work on it. I'm hoping to get it back on the road for him by this June. Is there a 930 specific checklist of things I should expect to change or inspect? I have a good amount of experience maintaining, building, and racing my own vehicles (94 RX7, miata, basically imports), but I'm not sure if there are Porsche specific things I should expect. At minimum, I'm assuming I should check/replace any rubber hoses or couplers and drain all fluids. Any special tools I should start looking for? Thanks in advance. Definitely looking forward to this project. |
the fuel system will be completely gunked up. the fuel head will need cleaned along with injectors, etc.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
I would also put in a new, freshly charged battery. If there was any fuel in the tank it will need to be cleaned out before you add fresh. Do an oil change. And have a good read of the "why my car won't start" sticky thread.
Non User
+1 on the comments above, especially the “car won’t start” thread. Also, post your location, lots of good people here willing to lend a hand...
Infraredcalvin - AKA Pat '76 Turbo Carrera #311 - Factory LSD, Sport Seats ‘71 914-6 GT 3.4L twin plug track car '75 914 GT clone project '71 914 track car, fresh 2165 FAT motor (for sale soon) |
+1 on refreshing the entire fuel system *before* you try to start it! If there's one thing CIS systems do not tolerate, it is contamination.
* Drain the tank, remove and have flushed (eliminate scale and/or rust), replace the strainer and seal and seal (foam) to chassis * Replace the 12mm (1/2") ID rubber hose from the tank to the front pump * Flush out the chassis lines, blow out with compressed air * Replace the fuel filter * Test the fuel pumps, replace as necessary * Remove the fuel distributor, warm-up regulator, and injectors for professional cleaning and testing -- TurboKraft offers this service, as does CIS Flow Tech When reinstalling the system, bypass the CIS by connecting the FD's fuel supply hose directly to the fuel return line. Add fresh gasoline, energize the pumps, and flush the system again for 15-30 min. The rest is like resuscitating most any other older car. Change the oil & filter, check the plugs and replace as needed, etc. Be prepared for oil leaks from dried out seals.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Here's a list to get you started lol p/n's for '86 Cali car 911 602 102 01 Dizzy o ring 911 602 801 00 Coil cap 901 602 502 00 Coil 901 211 194 00 Heater duct RHS 901 211 196 00 heater duct LHS 930 110 122 00 Airbox to intake 999 701 469 40 inter cooler inlet 930 110 379 00 inter cooler inlet 930 110 230 00 pressure pipe to turbo 999 701 473 40 pressure pipe to turbo 999 701 477 40 ic outlet 999 701 468 40 bov housing inlet to throttle housing 930 110 197 10 (2) bov housing to flange 930 110 401 01 thermo valve 930 606 117 03 temp sw 900 123 007 30 (2) sealing ring for above 930 107 791 01 breather cover gasket 911 606 230 00 oil pressure switch 999 707 314 40 thermostat o ring 999 192 176 50 alternator belt 999 704 172 50 oil cooler top 999 704 017 50 (2) oil cooler bottom 911 107 176 03 oil tank plug 900 123 011 20 sealing ring |
Non User
Another thing, since you’re not familiar with working on Porsches, make sure you understand how to put oil in the engine. The 930 takes a ton of oil, but the last few qts should be with the engine warmed up and thermostat open. Lots of stories of overfilling and dropping the dipstick into the tank...
Thanks for the tips so far!
Engine up to temp, on level ground, and running.
very good!!!
