Stranger on the Internet
patkeefe's Avatar
930 manifold on an SC
Does the 930 intake manifold simply bolt onto an SC? I have grown tired of fixing plastic airboxes. I'm thinking I can just as easily put on a 930 manifold (or a 3.2, for that matter), now that I've converted to EFI. What's up with spacer blocks I have read about in the past? Is that something necessary?
Patrick E. Keefe
78 SC
Old 03-25-2018, 01:16 PM
lake wales fla
3.3 manifold
yes patrick the 3.3 manifold will bolt up to a 3.0 head you will just have to match the port size and change the studs. the 3.2 manifold is better but much pricier and a little more work to adapt. if you go that route i think chris carroll from turbowerks has a nice install kit fairly reasonable. here is a pic of of a 80 3.0 with 3.2intake
Old 03-25-2018, 02:54 PM
lake wales fla
yes you will need injector blocks best bet is billet alum. for efi. contact chris carroll
Old 03-25-2018, 02:59 PM
dos531's Avatar
Once you add in the injector blocks for efi, its cheaper to go with the 3.2 manifold.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'12 Gallardo LP-570-4 Performante
Ducati 748R
Old 03-25-2018, 03:53 PM
patkeefe's Avatar
OK, thanks guys.
Patrick E. Keefe
78 SC
Old 03-25-2018, 04:14 PM
