Turn Signal ?
I am having a problem with the passenger side front turn signal on my track prepared 1982 930.
Drivers side front and rear work fine, rear passenger side as well. I have done all the basic stuff swapped bulb left right - OK cleaned bulb and socket connections - OK checked the ground (brown) wire.- seems to have a good solid ground - it goes through the headlight socket to ground I removed the fixture and have the wires all separated so i can check them. The black with white stripe wire is the turn signal wire. With ignition on and the turn signal activated I get voltage between it and the ground of about 3 volts. This voltage pulsates just like you would expect to see at the turn signal. Appears i don't have enough voltage to light the light? Any thoughts? Thanks Bob |
I think That the wire attached to the top of your turn signal fuse lost contact.
Open the fuse box. The fuse "blinker light left" mount has three wires coming to it from top, all three held by the screw painted yellow; one of two thinner wires (red with a black stripe) is loose. You will be able to pull it with your fingers. You need to stick it back firmly and tighten the screw with a flat screwdriver - do not worry about the yellow paint. Confirm the wire is tightly held for a good contact. |
Thanks. I did check that and thy were OK. it turned out to be the wire from the headlight bucket to the signal. Somewhere in between there was a break. Ran a new wire though and all is well!
| All times are GMT -8. The time now is 12:52 PM. |
