-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   ‘76 930 wastegate adjusted all the way out...why and what to do. (http://forums.pelicanparts.com/showthread.php?t=991431)
jkarolyi 03-22-2018 06:43 PM
I’m helping a friend who inherited a long stored, very original ‘76 930. After going through the entire fuel system, I noticed the wastegate was adjusted all the way out. Why would someone adjust it this way? What should I do to correct it before running the engine?
http://forums.pelicanparts.com/uploa...1521769397.jpg
slyguy 03-22-2018 07:01 PM
Rawknees is the only guy I ever known to be sticking straight out like that. That thing will poke your eye out. And clearly unprotected. Be careful, he's real dangerous when he gets excited like that.
slyguy 03-22-2018 07:04 PM
That's not a factory adjustment (there is none), it is a bolt plugging the boost vacuum port
Rawknees'Turbo 03-22-2018 07:05 PM
That is a homemade boost controller. Normally that port is vented to atmosphere (allows the diaphragm to move under air pressure supplied to the side of the bell). Originally there was a metal tube screwed down there that went up through the engine tin and into the engine bay (to keep water from getting in there). One simple thing you can do is put a hose barb fitting in place of that nut/bolt combination and then run a hose up and into the engine compartment.
By the way, someone made that modification in order to run higher than stock boost - not a good idea if nothing was done to monitor and adjust fueling (onboard AFR gauge and adjustable WUR).
Rawknees'Turbo 03-22-2018 07:06 PM
Can't be me as the car is not lifted way up in the air on the left!!! :D
slyguy 03-22-2018 07:12 PM
sounds like a little air jack going on here
Rawknees'Turbo 03-22-2018 07:26 PM
Hot air?!?!
slyguy 03-23-2018 08:31 AM
Originally Posted by Rawknees'Turbo (Post 9972174)
Hot air?!?!
Free flow? through the missing wastegate nipple? sounds nasty
heliolps2 03-23-2018 09:10 AM
That was funny .....http://forums.pelicanparts.com/support/smileys/lol2.gif
1979-930 03-23-2018 10:34 AM
Extremely dangerous place to ask for advice.
The answer is seldom what you expected with this group.
Sent from my iPhone while Driving
jkarolyi 03-23-2018 08:26 PM
Haha I don’t mind the funny replies.
Thanks for the helpful info Rawknees...I’ll replace the bolt with a barb as you suggested. The wastegate internals won’t be affected by converting back, correct?
Rawknees'Turbo 03-23-2018 10:47 PM
That's correct - no effect on internals.
The purpose of that bolt is to limit the amount of movement from the diaphragm, and thus the spring and valve, buy blocking, or lessening, the flow of air out of the "bell" (the topside of the diaphragm) - a crude boost controller/increaser.
Nasty is the only way I roll, bro (well, other than kinky, too!)!
turbo nut 03-24-2018 08:12 PM
That will up the spring pressure to increase boost. It will add more preload on the spring. But it still needs to be vented or it can be erratic. I drilled a hole through the bolt. Did this for years
