-   911 Engine Rebuilding Forum (http://forums.pelicanparts.com/forumdisplay.php?f=257)
-   -   Camshaft housing sealant? Curil T? (http://forums.pelicanparts.com/showthread.php?t=1072314)
$yncro 09-05-2020 04:18 PM
Hi there, just finished one side of the camshaft housing to head install..
Did I make a mistake by using Curil T for the sealant? I was so stoked to
Put it together and I thought I had to use Curil T then looked back in Wayne's
Book, he said loctite 574! $h/t!! Or is that ok? Did some searching couldn't find
Answer. Should I disassembled and redo?
TIA.
Ended up taking the cam housing off the heads, cleaned and installed it back with
The right sealant.
All good.
mikedsilva 09-06-2020 01:45 AM
Glad you re-did it!
That was the right move!
