The 9 Store
If you are rebuilding your heads, your machinist should be able to remove broken studs and fix damaged threads. It’s such a common issue on Porsche heads that I would be worried about a machinist who couldn’t do a proper job.
All used parts sold as is.
Old 11-23-2025, 01:36 PM
Hi
Suggestions
While the engine is in the car any stud that is functional is good.
(It isn't broken; leave it alone!)
If it needs repair, in the first instance try to use a stepped stud.
Cheers
Old 11-23-2025, 02:35 PM
