I always try to stay out of these discussions as I am an engine person, not an electronic guru.
I have always deferred to Wayne at M&W for Ignition advice over the past 25+ years.
In reading all of the posts here, there is something missing. Something way more important TO ME!!!!
No disrespect meant to you Fred, but you are always missing the most important number in any of your posts, TO ME!!! THATS ENGINE TORQUE produced.
As an engine person, I could care less what the internals have, I want to see a torque increase on the dyno, driver response on throttle response and reliability.
An engine is the sum of its parts. I want the best parts possible in every area of the engine. If the
CDI I choose produces more torque in testing, and is reliable, I'm buying that one. That is job #1.
Wayne has always come through for me on every system we have purchased from him and we have found in over multiple engines, the CDI system we use produces the most torque in all of our testing.
Our name is Performance Developments so developing performance is our DNA. Spark plug life is not important to us. Plugs are cheap!!!!!
These large chambered engines with domed pistons, ports that do not flow well, have a lot of reversion and messy air flow when the throttles are opened, need all the help they can get. The ignition is the last event to happen, so make it worthwhile.
To me, reading all about the testing that has been done, is all too much about the "pointed hat" syndrome.
If you want to sell your Ignition system to engine people, sell them engine performance gains.
That is what Wayne sells to me.
Old 05-17-2021, 07:54 AM
Neil, Torque, Yes, but one can't mention everything. This morning I had a short discussion with the fellow that gained 20% in mpg on his Healey. I mentioned that I'd bet that with full combustion starting earlier that his exhaust temperature would be lower as well. I was flabbergasted when he came back saying the temperature was indeed lower (numbers coming later). How many people have dual exhaust temperature gauges installed permanently on their antique cars? This is the first guy I've run into. In addition to manifold vacuum, this is yet another useful diagnostic tool. Oh, and I'll bet the torque is up. Has to be actually given the increase in mileage and the lower exhaust temperature but most of us only have a butt dyno to prove it. Fred
Old 05-17-2021, 08:06 AM
Fred
We are a small company specialising in high reliability and performance cdi systems from 115mJ up to 2,000mJ. Between us we have 80+ years experience with over 10,000 cdi systems sold and that quantity again of inductive modules although we no longer make these. Our early designs used a continuous mode flyback transformer and conventional scr technology however due to their limitations this was quickly changed to quasi resonant transformer drive and high side firing IGBT’s which, with their significantly improved electrical characteristics, allowed us to turn away from conventional cdi theory.
Our ‘experiments’ as you kindly put them consist of real world testing on AVL / Kistler instrumented Australian, European and US engines both single and multi cylinder. We do have spark gaps, pressure chambers, Zenner strings and a plethora of other ignition specific equipment however test bench experimentation often doesn’t equate to in cylinder results. Using new theories we were able to find noticeable improvements in engine power/torque and an increase in fuel mixture tolerance using a completely different ignition profile to your proposal. So far this has held true for all fuel types tested including gas (LPG), petrol, alcohol and nitromethane.
Yes you can reduce plug erosion by altering the discharge characteristics however we are a performance company therefore to do so is contra indicatory.
When you say ‘a few corrections’ and ‘indeed facts’ this assumes your point of view is the only valid one however perhaps it would be wise to consider nothing absolute as new discoveries are made every day on subjects once considered final. About the only similarity between our designs and those of you and your late father is that they both discharge a capacitor into a coil.
M&W stands for Mark & Wayne
Originally Posted by Fred Winterburn View Post
Jeff,
I could go on forever. I have never tested an M&W CDI. I certainly agree with M&W on mJ outputs as those numbers are almost meaningless unless the whole package is considered. My R&D budget is pretty small but I have managed to find things through experimentation that aren't so well known. The only modern CDI that I have run on a car and which isn't so modern anymore was an Accel 300+ digital CDI. It needed more than 10V to operate so I had to run it off a dedicated battery while the engine was cold and on the starter. It was indeed hard on the distributor cap and the plugs. The rest of my experience and research is mainly entrenched in what was built during the sixties for historical reasons. I have tested and have quite a few in my collection now from various manufacturers. Half of these infringed on my father's design from 1962 (patent filed 1963) which in 1963 became the Hyland CDI (I have no idea why it was called Hyland). Sydmur, Tiger, Delta, Speedatron, VJ Products , Magnetti Marelli AEC101 were amongst those that infringed. VJ Products was the only company to pay royalties. An interesting one that didn't infringe was the Tung Sol(Motion) EI-4. They were in production before my father's but are tube type. A spark duration of only 3µS and being tube type, not destined for a long life. I have two of those in my collection now, one a positive ground unit and the other negative ground. Those units are something to behold. I also have several Hyland units and they were made cheaply to keep costs down, although they were quite reliable. A Tung Sol CDI cost $120USD in 1962. The Hyland was first solid state CDI to be put into production and it cost $35 in 1963. My father had been building CDIs since the early fifties using thyratrons but those kept failing in just a few months so when the SCR came along he latched onto it. Another interesting one built about 1966 and the first to use the Theodor Sturm patent (filed just a few days after my father's patent), made in San Diego, was the Blitz Funken. The Blitz Funken predates the Permatune that also used the Sturm patent. And yet another one I have that must date from the late sixties is called the Hot Box and has a knob that can adjust the rev limit. It was made in Seattle area and I'll bet no more than two or three were made. Quite badly done and the rev limiter doesn't work well at all but also a neat piece of history. Another really interesting one is the Compu Spark that Tom McCahill pushed for years in magazine advertising. It is a true double spark CDI with the sparks coming 200µS apart which is quite a useful separation (MSD is 1mS). The only modern equivalent to the Compu Spark would be Jonny Hart's CDI+. Mine multi-sparks differently and longer if the right coil is used. I'm looking for a Stevens CDI to add to the collection but doubt I will ever find one. They were very powerful, expensive, but were meticulously voltage controlled. And of course I have a couple of MSD 6As that I play with from time to time. The problem with most CDIs is that either they have no voltage control or the voltage is way too high for longevity in distributor type street cars. The worst in my collection is the Hot Box that uses an old filament transformer oscillating at 50Hz. It puts out up to 70 thousand volts at idle but runs out of steam quickly to no more than 12 thousand volts at 333 sparks/s.
Anyway, After my Dad passed away, I decided I wanted to make a few using his design for my old cars, but they needed to look good so I decided if I was going to that trouble I might as well sell a few too. So I developed one with a longer duration, and compatible with either positive or negative ground (without any switches or wiring changes). Every one I make now is basically a copy of the final prototype. Labour intensive construction techniques. The power supply is different than the old Hyland and unique from any other in a few ways. It's not a Royer variant like most of the old supplies either. It has two supply transistors but will run handily with just one up to a certain rpm. To date I have built just under 250 units in 7 years and expect I will quit this hobby in another two or three years so I will have time to restore my old cars and keep up with chores on my country property. Just got an email yesterday from a fellow with an Austin Healey. He reported that his gas mileage went up by 20% with the CDI. That kind of report makes me feel good about the product and my take on my father's old design. Old fashioned it may be, but it still does the job, and does it rather well. Fred
Old 05-17-2021, 12:37 PM
I'll ask again, what modern car(s) use CDI? In the last 10-15 years?
I'm not saying that everything used by major manufacturers is the "best," but they do have to meet emissions and reliability standards, along with performance standards, and are consistently judged by their consumers and competition. There must be reasons why they choose the ignition systems that they do.
Old 05-17-2021, 12:56 PM
Racer
winders's Avatar
Even NASA is going away from CDI systems on their rocket thrusters up to 10,000 pounds thrust. They are now using an inductive ignition system that is significantly cheaper and works much better.
Mission Ignition Systems (Mark Lepore), who make the inductive ignition system I use on my race car and who I quoted in the first post, provide NASA with the inductive ignition system.
In the past, race cars could not use inductive systems because the dwell times did allow for higher RPM functionality. Well, that is no longer a problem. Inductive ignition systems can work up to 20,000 RPMs.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 05-17-2021, 01:50 PM
Mark (or Wayne?), Testing or experimenting; all semantics to me. That wording was not intended to be insulting, although having worked in nuclear for years, I know our bosses did not like it if anyone said 'experiment'. "We don't experiment with nuclear power!" I only had 3 corrections to what you wrote. They were factual regardless, and not simply my opinion. The physics are what they are and I thought worth mentioning lest others take it at face value. I didn't just fall off the turnip truck. I always give latitude for differences attributable to other designs but some fundamentals remain. (such as a CDI consists of a capacitor discharging through a coil). I do think it's great that you have made breakthroughs with the technology. Lots of ways to skin cats, but some methods work better and by all accounts your products are excellent. And yes, I dislike it when folks assume that all CDI designs are exactly the same. This is one field where the variations are much wider than most people realize. Fred
Originally Posted by M&W Ignitions View Post
Fred
Old 05-17-2021, 01:53 PM
Jeff Alton's Avatar
Fred, thank you for your detailed answer! Quite the history!
Cheers
www.turn3autosport.com
Old 05-17-2021, 07:58 PM
Ingenieur
Modern engines use much less oil than engines from the ‘60’s and ‘70’s. They use fuel injectors that deliver precise amounts of fuel and are controlled to virtually eliminate fuel fouling. The same controller can drive a coil for each cylinder, tripling or even quadrupling the inductance of the systems.
Compare that to an aircooled, carbureted Porsche engine with a dude and a gas pedal controlling the start fueling, and oil consumption that is bad to horrible by modern standards. So you can see that a COP is really the ideal ignition for a modern engine. The mixture is meant to be easy to ignite, and there is normally no oil fouling, something that a CDI ignition excels at solving.
Keep in mind that it is the temperature of the spark that ignites the mixture. That temperature is produced by ionization energy from the ignition, and once you get to that temperature, more energy doesn’t do anything. The inductive ignition can keep the ignition temperature hotter for longer than CDI, but CDI can also provide multiple discharges in some conditions to narrow that benefit.
A problem with CDI on a modern engine is that the intensive refinement of shift behavior, traction, emissions, and fuel efficiency is produced in part by slewing the spark rapidly between operating points. You would have to have a CDI with multiple capacitors to get the slew rates that an inductive COP system can produce easily.
Old 05-20-2021, 07:57 PM
Let us start out by stating cdi ignition is not for every application or for every person. Both inductive ignition and cdi ignition have their purpose and you can not state without qualification one is better than the other. Also remember we are a performace oriented company therefore do not get involved in unmodified factory vehicles.
Huh! Dont remember the last time we measured a COP style coil which has more inductance than an external coil, generally they tend to have less inductance due to restricted room for windings and little to no room for the magnetic core.
Here you are getting back into the old myth about longer arc duration being more optimal which has been proven false in many scientific papers. As per an earlier message the ability to ignite fuel is 'EI' Energy multiplied by Time. If you lack one you need to make up with a lot of the other. Multi discharge is also useless except in very limited circumstances as the crank has moved too far between sparks at anything much above idle. Multi dischage is used by both cdi and factory inductive ignition to help solve cold start emission issues on some modern engines.
Not sure where you are coming from here, that does not make any technical sense to us what so ever.
CDI ignition can be ready to fire the next spark in less than one third the time of the fastest inductive ignition system and is far superior in dealing with agressive timing changes and firing interruptions than inductive ignition. CDI ignition is edge triggered and automatically recharges for the next event after firing unlike inductive ignition which requires a precisely positioned leading dwell period to prepare for the next firing event.
Last edited by M&W Ignitions; 05-21-2021 at 06:12 PM.. Reason: Technical corrections
Old 05-21-2021, 02:52 PM
I really wanted to make a few corrections, but this time I couldn't. I would like to know the absolute reason why CDI is not used in a COP system anymore (other than Saabs older system). The slew rate thing has me confused. More capacitors? Doesn't make sense to me either. Perhaps more detail would help. I can say that after re-comissioning my wife's Honda Fit as we are coming out of Covid that it fired right up on the first compression like a CDI. That engine behaves like a CDI is installed but I'm pretty sure it's inductive from what I've read. Never a misfire or a stumble. Compare that to my coil near plug Chev truck that will start to misfire if idled too long (brings in a misfire code too). Fred
CDI ignition can be ready to fire the next spark in less than one third the time of the fastest inductive ignition system and is superior in dealing with agressive timing changes and firing interruptions than inductive ignition. CDI ignition is edge triggered and automatically recharges for the next event after firing unlike inductive ignition which requires a precisely positioned leading dwell period to prepare for the next firing event.
Old 05-21-2021, 04:37 PM
Fred
It is not used mainly due to cost and service interval. There is another not well understood problem with COP/Pencil coils when used with cdi ignition due to their less than ideal magnetic properties (simplified) although we have noticed recently the changes to Bosch pencil coils which should reduce/eliminate the problem.
SAAB used cdi originally as it allowed them to more easily implement spark plug ion current monitoring for knock detection however now there are a number of inductive ignition coils with this feature built in such as those used by Haley Davidson.
Old 05-21-2021, 06:22 PM
Certainly the main reason must be cost versus reward. COP solves several of the problems which CDI solved first with distributor systems, but it can't solve all of them completely (IMO). With regard to pencil coils not being suitable. That reasoning would only apply to the CDI aftermarket which might want to mate with some OEM inductive coils. It wouldn't be hard for a car manufacturer or supplier to make coils specific for CDI use. Cheaper actually since they don't have to be high inductance.
An old example of a CDI design being compromised to suit OEM coils is the MSD6A. One of the reasons (this time just my opinion) the MSD6A CDI has that grotesquely long gap of1mS between spark events(other than more time to recharge the capacitor) is that with a high inductance coil and a shorter interval, there can be destructive interference affecting the strength of the second and subsequent sparks. To give time for opposing voltages to ring out, the interval has to be longer. The 1mS interval means that the second spark is only useful at slow idle and all the extra sparks are completely wasted above that. 1mS turns into a lot of crankshaft degrees where nothing is happening. (every 1000rpm= 6 degrees). And yet MSD sold many thousands of these CDIs which only work effectively because of the first spark in the series. Fred
Fred
Old 05-22-2021, 05:20 AM
Jonny H's Avatar
I've so far just been reading along, nice to see the Cosworth DFV mentioned, we've been reverse engineering and redesigning the Lucas CDI of recent.
It's taken a couple of years of design and tooling but we finally got our first batch of production CDI coils. 100% hand made in the UK.
https://www.classicretrofit.com/collections/cdi-ignition/products/ignition-coil
CDI COPs btw:
https://www.mclarenelectronics.com/Content/Products/Ignition%20Coil%20CDI/Ignition%20Coil%20CDI.pdf
Should be on Pelican soon.
Old 05-24-2021, 04:07 PM
We were aware of those coils however they were designed for a very specific ignition system and when you have complete control of both ends, cdi and coil, you can mitigate the magnetic issue not remove it besides a set of them would break the bank of most people.
Nice looking coil you built, what leakage inductance were you able to achieve?
Old 05-24-2021, 07:36 PM
Jonny H's Avatar
Thanks!
The coil geometry is similar to the original Bosch black coil so leakage should be similar also. Being a high voltage pulse transformer, the dominant factor is the insulation.
Our focus has been on production process and breakdown to improve quality. Something that Porsche seem to have forgotten!
Would be interesting to measure though.
Old 05-25-2021, 10:27 AM
That could turn out to be a very expensive and dangerous assumption. There is a company known for their Almost Engine Management who attempted to copy the much used Denso pencil coil with absolutely disasterous results. That coil went on to damage more ignition systems in the world than you could possibly imagine.
For the coil maybe but not the ignition system.
Old 05-25-2021, 06:08 PM
304065's Avatar
Fun thread and I like how you folks are staying away from ad hominem attacks. As I say on the opening post of this forum, this is a forum for exchange of information, and naturally some people hold passionate views. And none is so sacred that it cannot be respectfully challenged with data.
Since we appear to have more than one electrical engineer here, I wonder if you have any comment on this old thread, where I attempted to quantify the extent to which ignition energy from an inductive system declines as RPM increases, and how that changed with transistorized ignition and low-resistance, low-impedance coils.
http://forums.pelicanparts.com/porsche-911-technical-forum/640218-crane-xr700-capacitive-discharge.html
Not to hijack but maybe some people might find it interesting.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 05-25-2021, 06:47 PM
Jonny H's Avatar
We’ve had this coil in test for over a year now. It’s been extensively tested with Bosch and our own CDI+ units.
The coil is closely related to a series of coils produced for historic race and rally cars which run a variety of different CDI units,
What’s your view on the multitude of 911s that are running incorrect (many are inductive) coils with CDI units?
Old 05-26-2021, 05:15 AM
My observation from having run EDIS waste spark for 10 years in my SC until last year converting to dual M&W CDIs and coils, with a 12 point JB distributor is I could not detect any difference. Sorry
EDIS inductive ignition is cheap and very easy to install and set up. As opposed to the current setup which was expensive and gives less freedom in the ignition tables wrt rotor phasing.
Engine runs beautifully but if there is any improvement I can not feel it. At least it is not significant in my car. It appears to me that inductive ignition may work pretty well and that CDI may work well too. At least with EFI in my engine.
I like the looks of those two shiny black M&W CDIs and the beautiful JB distributor is worth some and no regrets. But I could have taken a cruise in the Caribbean instead or bought a seat on the next space shuttle. Not that I would want to
80SC (ex California)
Old 05-26-2021, 07:16 AM
I know that one of the limitations with inductive ignition systems has always been the dwell time because of a single coil.
With the proper coil design, i.e. primary inductance/resistance & turns ratio, and using an IGBT switching device, max RPM relative to dwell time is no longer problematic.
Did ALL of the manufacturers shy away from CD ignition systems because of cost, or are there other variables in play?
"Shy away" doesn't properly describe what occurred. Presently, most all OEM automotive manufacturers only use inductive discharge ignitions (IDIs) because;
1. When using a IGBT to drive an IDI coil, the system ECM microcontroller can directly drive the IGBT, basically reducing the old technology CDI design to just one component.
2. Additionally, by eliminating the capacitor of the CDI from the design, system reliability was increased.
3. When using a COP (coil-on-plug) ignition design with a CDI spark design, the ignition ECU cost would be prohibitive.
Since we're Porsche specific here, when was the last Porsche CD ignition system used?
Last used on the '83 911SC.
Wasn't it in '89?
No. All Porsche engines beginning with '84 911 3.2 used IDIs.
Why did they quit using it?
Because of significant improvements in semiconductor switching device technology of the late '70s & early '80s, significant cost reductions resulted with improved reliability, when using IDI designs.
Dave
Old 06-04-2021, 07:40 PM
