Try not, Do or Do not
Variety is the spice
We've been busy in the barn.....
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Damn.... "busy" is an understatement. What an attractive array of builds......wish one were mine!
Very impressive, and most are for 914/6 applications. Would you use a stock 914/6 oil cooler with these builds, or a modified larger tube cooler?
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
Looking good Henry!
Sent from my iPad using Tapatalk |
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 04-30-2023 at 08:13 AM.. |
You make these or are they commercially available?
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
These are custom made for us. We have a few sets for testing but our plan is to offer them to our customers on a priority basis but should have a few sets for sale. The headers are compact and designed to fit 911 and 914/6. They fit most 911 mufflers but there are megaphones in the pipeline. We are also working on twin and single turbo attachments. The compact size and V-band clamps make these headers incredibly adaptable.
Uncertifiable!!!
Wow, eye candy.
Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
Now that is one spicy lineup! Could you provide more information about the build and performance specs for the 3.9 EFI and 3.8 High Performance engines?
The 3.9 is a pretty mild street build. Target 310 hp?
76.4mm 964 crank Forged H beam rods 964 case converted for Carrera fan & housing 964 heads mild porting [clean up] Custom made [in house] 104mm Biral cylinders (Nikasil coating) JE 11.5:1 compression Supertec head studs 993 Super Sport cams Custom 3 to 2 intake conversion plates 46 mm butterflies reduced to 41mm ports 63mm air horns [velocity stacks] ITG air filters Plans are to run a Haltec management from Clewitt engineering. The exhaust is a custom made header system with Dansk Sport muffler. The 3.8 is a long block just finding it's way. [no home as of yet] It is being built to fit an earlier [<90] chassis, and have a early engine feel. 911 fan and housing, early motor mount and cross bar. 964 core Target hp around 340+? CP 12.0:1 DC43 /109 camshafts 964 heads with 51mm/ 8mm 993 intake valves Carrillo rods 996 TT oil pump Supertec head studs IWIS racing chains Series 900 Amber shroud It will run either custom B&B heater boxes or my new design headers The next step is the question mark. EFI Slide valve, Clewett ITB, Supertec ITB or 50PMO, If someone steps up I might even build it as an MFI.[I have them all in stock] Distributor or COP. Dist obviouly has the early esthetics. There are a lot of people building IROC replicas for Dave's new series. This might be a great candidate.
Answering another question:
The 3.2 Short Stroke High Butterfly CUSTOM BUILT TO 3.2 PERFORMANCE SPECS (280+ HP) 98mm 10.4 TO 1 COMPRESSION MAHLE PISTONS (thermal & dry film coated) MAHLE NIKASIL CYLINDERS 98mm SHUFFLE PINNED 3.0 911SC CASE FACTORY CRANK (balanced, cross drilled, Plasma Nitride) 70.4mm CARRILLO CONNECTING ROD DRC BILLET CAM SHAFTS (DC62 102 LC ) *MAIN BEARINGS (GT3) *ROD BEARINGS (CLEVITE) *GT3 INTERMEDIATE SHAFT BEARINGS 996 TWIN TURBO OIL PUMP COMP TIMING CHAINS AND RAMPS SUPERTEC IDLER ARMS CARRERA CHAIN TENSIONERS *RECONDITION ROCKERS AND SHAFTS COMPLETE ENGINE BALANCE SUPERTEC HEAD STUDS 906 COOLING TIN BIG PORT 911 SC CYLINDER HEADS COMPLETE VALVE JOB W SILICON / BRONZE GUIDES AASCO VALVE SPRINGS TITANIUM VALVE RETAINER STAINLESS SILVER LINE VALVES (50MMX47MM) 40 MM INTAKE PORTS 38MM EXHAUST CUSTOM PLUG WIRES CUSTOM BILLET VALVE COVERS COMPLETE CUSTOM MFI SYSTEM CUSTOM PUMP, NYLON 11 FUEL LINES SUPERTEC COLD START DEVICE HIGH BUTTERFLY WITH CUSTOM FIT ITG AIR FILTERS TWIN PLUG DISTRIBUTER, PLUG WIRES, HOLDERS MARRELLI TWIN PLUG & MFI CONVERSION(HEADS) BURNHAM PERFORMANCE SUMP COVER RSR STYLE LIGHT WEIGHT FLYWHEEL SUPERTEC STAINLESS STEEL HEADERS DANSK SPORT MUFFLER AMBER FAN SHROUD & PERIMETER TIN DRY FILM LUBRICATE ALL BEARINGS NEW 75 AMP ALTERNATOR CUSTOM ENGINE HARNESS
PCA Member since 1988
Henry, why did you use H-beam rods instead of I-beam rods?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
The reasons are brand recognition, US made, consistent quality, and most importantly, readily available.
We can have a theoretical argument about what rod design best suits the 911 air-cooled engine but if the quality control is top notch, design doesn't really matter. These little engines do not create enough stresses to exceed the design perimeters. I mention design availability because Carrillo seems to be the only company producing consistently great rods that fit our engine needs. If I had deep pocket, I would design a line of affordable connecting rods for every air cooled configuration. They would probably be an A beam rod [light and strong] with longer center to enter lengths for each application. Pankl titanium are my favorite go to when the appropriate application avails itself. In every instance [except the 2.0/2.2], the Porsche design rod is too short. This was a function of retaining consistent engine dimensions as the engine got larger. Being a small company, Porsche sought to transition from one engine seize to the next with the least amount of change. As the stroke got longer the rods got shorter. Theoretical rod length to stroke ratio for these engine should be around 2:1. The 2.0/2.2 was close but by the time they produced the 3.6 the ratio was closer to 1.6 to 1. As long as RPM was not the goal, these numbers are acceptable. You may notice that 3.6 engine seem to be designed for a 6400 red line. 2:1 theoretical rod/stroke ratio reduces rods angularity and frees up the engine by creating longer piston dwell, reduced piston side loading, friction and ring fatigue. We use a multitude of rods in our builds based on design parameters and budget. Overkill is easy when "the best" is the goal. Overkill like Carr vs WMC bolts in Carrillo rods. The WMC bolts are rated at 1100 hp vs the Carr bolts at 1500. Our engines rarely exceed 500hp so what's the point? These Pankl rods were installed in a 2.8 short street engine. It is capable of a safe 8200 red line. Cams to produce that silliness on street gas are a little high strung but that is what the customer wanted. This little engine went in a 71 narrow bodied "R" type street car.
Sticking to the rod conversation:
The 2.0 race engine we just built for a 914-6 GT historic car used a combination of Pauter rods and a custom crank designed to use Chevy 2.0" journals with Clevite rods bearings. The X beam rod is rarely discussed amongst the "best" rod designed but the quality of materials and attention to detail of the Pauter rods makes them a reasonable choice for 911 air cooled engines. I believe one design theory of the X-Beam rod is reduced oil collection. Oil collecting in/on horizontal rods can create an imbalance.
In post #5 what is the oil filter used with the 993 console?
It is a high performance VW filter that we modify to fit the Porsche console.
We're in the process of prototyping a new oil console.
Henry, thanks for the info on rods. I'm familiar with the theoretical discussions about rod shapes, but if getting the best length for your application requires the use of rods made by Carillo or Pauter, then I totally understand the choice. I would choose a longer rod too, and a tight ring stack, given the trade-offs.
It's hard for me to imagine that oil can collect on a rod shaking like a wet dog on amphetamines at 8000 RPM, but I'll take your word for it!
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 05-19-2023 at 02:47 PM.. |
I like the one on the far right
Henry, does the filter eliminate the pressure drop across the filter. I’m currently stuck with OC229 on a 993 console because of space.
Constitutional Liberal
That one piqued my interest as well. Maybe Henry will give us more detail.
3.0 short stoke with titanium rods.......wow! Quote:
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
