Originally Posted by -Levi- View Post
As far as AFR go, we are mid to low 13s to high 12’s depending on the exhaust setting and rpm.
Would these numbers be sufficient to drive the car as is on the street and Drivers Events?
Looking at your lambda graph, I think you'll be fine. I'd be comfortable with this.
Always learning.
www.aircooledporsches.com.au
Old 05-10-2025, 04:23 PM
Banned
I'm interested in exploring options for integrating an aftermarket ECU with a Varioram setup. What solutions or approaches are available?
Old 05-12-2025, 10:14 AM
Bump, anyone else have any thoughts?
81 SC 3.8 Conversion
2017 Macan S
INSTAGRAM @tail_spinz
Old 05-16-2025, 09:55 PM
targa72e's Avatar
Based on the data provided I would say the red line is borderline OK. The Blue line is too lean.
General guidelines
12.2 AFR - Safe Best Power at Wide Open Throttle (WOT)
13.3 AFR - Lean Best Torque.
14.6 AFR - Stoichimometirc Air/Fuel Ratio Value (Stoich)
15.5 AFR - Lean Cruise.
16.5 AFR - Usual Best Economy.
I think you would want closer to 12.5 at wide open throttle. You might also want to try measuring your self with a wide band O2 sensor. Since the one a Dyno Pro is inserted in the tail pipe it is probably not as accurate as one screwed into the exhaust pipe.
john
Old 05-17-2025, 11:37 AM
General guidelines
john
Thank you,
I am running a dual wideband, one on each side and they match the dyno AFR.
2017 Macan S
Old 05-20-2025, 07:25 AM
