Intermediate Shaft Fitment
In my current 1983 3.0L engine assembly process, I have concern with the intermediate shaft bearing inserts. Both the end-play and the insert sitting high in the case. The case has been had the line-bore checked. The engine has never been apart since initial Porsche Factory assembly, nor has it had a catastrophic event.
End-Play: With a new shaft assembly, the thrust clearance was undetectable value. I saw a video, from a well know guy, about tapping the shaft to force the bearing into the case to gain clearance. All my manuals don’t touch the subject. The little spec book does give a value, but nothing on how to accomplish the value. The bearings are Glyco brand made in Poland. I had higher confidence on the Polish made pieces. I’ve heard that the ones made in South Africa have had issues. Bearing Shell Sitting Proud: I installed the shell half in the case and tapped it into the case. Both the bearing shell and the case were clean, free of burrs. The bearing shells sit proud by .015”. I have “Porsche OEM” bearing sets on order and will see how they fit. Any wisdom would be appreciated.
PCA Member since 1988
.015" is huge. Something is wrong. Are you missing a zero? Even .0015" seems too much for "crush" to hold the bearings tightly in the case, for such a small diameter bearing. Didn't see specs in the tech specs book.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 01-24-2024 at 10:03 PM.. |
Hey Pete, no missing zero. If it were .0015” I would feel comfortable with that amount of bearing crush. This much more than a fingernail feel test. I’m looking forward to the Porsche branded version.
They compress. They're all like that. Relax.
It's called "bearing crush" and helps keep the bearings located in the case or connecting rod without spinning.
Tapping on the end of the intermediate shaft to gain end play is the way that it's done. Use a dead blow hammer and a brass drift. |
Thanks reassured now.
What was making me question, and I know about bearing crush, was that the non-thrust bearing doesn't sit proud like the thrust bearing...Hummmm.
I'll defer to John Walker. .015" still seems excessive to me, but he's built more of these engines than I ever will.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
It's a 914 ...
I asked in another thread, but I think it's relevant to this discussion ... are there any concerns with using "regular" Glyco intermediate shaft bearings? Or use the Porsche sourced ones? Or some other brand?
My original concern was what seemed like two much height above the case. It’s a pretty small bearing and a whole bunch of material to crush upon closure of the case halves. I think i’ll remeasure now that the end play is set. |
It's a 914 ...
I'm suspecting that Glyco's issue isn't with rod bearings per se, but rather than whatever quality issues have crept in just surface in the most highly stressed bearings, namely rod bearings. And that whatever level of quality is sufficient for main bearings.
Not much discussion on the layshaft bearings though. They are highly stressed in a 911 engine, and I've heard they often show copper on teardowns. Just curious if Glyco's offering is acceptable. I'm not hearing too much discussion on it, maybe that's a sign. |
To add one more data point, I can't remember the last 911/930 engine where the intermediate shaft bearings were NOT worn or showing copper somewhere. Dozens and dozens of engines at dealership level.
Yeah, it appears to me that the tin layer on the IMS bearings is very thin, like it's a thin plating, rather than a layer of tin. It also appears that it gets worn off quickly, and then the bearings work for several hundred thousand more miles. IMS bearing failures are also very rare in these engines, unlike the ball bearing IMS failures in 996 engines. The more robust Metzger versions of the 996 engines used plain bearings too.
Have not pulled a single one apart that did not show copper on those bearings... Thats over 20 years and plenty each year... ![]() Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
abit off center
Torque up the case with the bearing but without the shaft and measure the bore, quit guessing.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Wow! I watched and investigated my engine and this is exactly what the problem is. Thanks, I really didn’t want to tear down for leaks…
It's a 914 ...
Damn. So now we have layshaft bearings that don't fit 911 cases?! Glad I saw this. I'll check on my motor that's about to go together.
Damn! Another crappy Glyco part. I ain't buying anything Glyco ever again. .015" was way too much for crush allowance.
If I didn't want to go through the hassle and time of returning/ordering new ones, I would file down and chamfer the collar of the bearing so that it sits all the way into the saddle, then make damn sure it is't too short!
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 02-01-2024 at 02:04 PM.. |
what's the answer here?? the breitwerks clip is alarming!- have new set of glycos due at my door tomorrow and guess i will be looking for little or no material proud of case- any leads on alternate manufacturer?
have plenty of files, and a healthy concern that engine will leak when i get it back together, too!- gonna leave the machine work to the pros-
have searched about a dozen parts suppliers- sorry, wayne- found a genuine porsche thrust set at auto atlanta- |
