Thanks to Dpmulvan for catching the bolts being installed upside down. Great catch. I'm the builder working with mike 491.
Old 04-03-2025, 05:42 AM
Connecting Rods Orientation…………
Stunistu,
Did you install the connection rods with stamped # all facing the same direction when all are hanging down on the crankshaft? Did you use stretch bolts? Thanks.
Tony
Old 04-03-2025, 10:50 AM
Yes, all numbers are in properly. I'm using ARP bolts.
Old 04-03-2025, 01:19 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Lucky you can re-use the rod bolts, not so lucky that the cases have to be split to correct the issue. I would look carefully at the rod bolts and mating rod surface to ensure no damage has been done to either.
1986 Targa Guards Red
2021 MT09 SP
Old 04-05-2025, 03:37 AM
It’s an easy mistake to make, most connecting rods have the nuts on the bottom.
House producers wanted to end the show after season 8 to keep the enigmatic appeal of the central character and maintain the show's mystique. Ahhh The Mystique!!!
Old 04-05-2025, 04:40 AM
Try not, Do or Do not
Henry Schmidt's Avatar
The connecting rods should be resized when installing ARP bolts. If they were rebuilt without the ARP bolts, they should be. If the were resized with the errant install they should be resized.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-05-2025, 09:16 AM
Reinstalled new rod bolts in the correct orientation and reinstalled case half. All turns nicely and pistons and cylinder hopefully next weekend. You can see, we should have seen, how well the anti rotation ears on the bolts seat perfectly in the recesses when on the correct side! Also can see what I think are gouge marks (north/south in the middle of the picture) in the case where the rod nut scraped the case when improperly oriented.
Doh! But not too expensive a lesson.
Old 04-14-2025, 04:59 AM
Take the engine all apart again and start over with the specs in hand. Have a good study of the Bentley repair manual, check all clearances, every bearing you've had off. If this was missed, what about the other details? Spend the time now not later.
81 SC.
930/16 (us model)
Old 04-14-2025, 07:35 AM
To be fair, the engine doesn't really get much more "all apart again" than down to the bare crank.
Old 04-14-2025, 09:48 AM
Originally Posted by 87m491 View Post
to be fair, the engine doesn't really get much more "all apart again" than down to the bare crank.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 04-15-2025, 12:33 PM
Constitutional Liberal
Turbo_pro's Avatar
Did you really just reverse the rod bolts without resizing the big end? I think as Henry said, that is a mistake that could cost you a spun rod bearing early during the break in period.
Jim
“Rhetoric is no substitute for reality.”
― Thomas Sowell
Old 04-15-2025, 03:36 PM
While I did have my rods resized with the ARP bolts (because in my 40 years of doing this stuff that’s what you do), I do wonder how necessary it really is in the OP’s case. Is the marginally higher torque value of the ARP bolts (5 ftlbs, maybe?) going to distort the cap to such a degree that it might shorten the life of the bearing? I’m skeptical- but have no data to support that. And I have never gambled on my hunch for any of my 5 or so various engine rebuilds, so it’s not a strongly held one.
Ken
1986 930 2016 R1200RS
Old 04-16-2025, 05:13 PM
