Try not, Do or Do not
We always use the best quality studs available but DIN 938 or 939 are pretty standard. As for your sump screen issue: What pump are you using? We are finding that some of the aftermarket pumps and sump screens have some fitment issues. You can probably manipulate the screen to accommodate the sump cover. I would suggest that compressing the screen (slightly) with the sump cover is generally required. When you retrofit a permanent screen pump (late 83 and later) in an sump plate case you will need a retrofit cover. Once again, not all the covers are made equally. We used to offer a sump cast aluminum sump cover but the tooling was stolen so the new product is still in production. How the screen should fit.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
My guess is yes, but I'm not in your garage holding your hand.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 11-02-2025 at 10:27 AM.. |
Maybe the screen screws deeper in or something? Will investigate. Micrometer shows 0.4 inches extended past the case. The generic curved plate I currently have has a 0.35 in gap when it's contacting the screen. The curved plate with oil drain that I got from our host has a 0.485 in gap. I had seen suggestions about shimming it out using the old second piece screens rim but it's far too big of a gap for that.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go! Last edited by OsoMoore; 11-02-2025 at 12:01 PM.. |
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
It's a 914 ...
That's really odd. I wonder if the venturi (the hole where the oil goes into the pump) is located correctly. Can you take a bottom view pic of the screen?
Do not shim the sump plate. Whoever suggested that must have memories of the deep sump on the type four engine.
Your best bet is to measure the distance from the screen to the venturi. Then compare that to the gap you are seeing when the sump cover touches the screen. If the gap to the venturi leaves you adequate space for oil the scavenge freely, you should be alright. If the gap to the venturi is less than say 6 mm, you will have to find another pump. There are some here who tend to be rather neanderthal so you might consider bending the pickup in place. If you go that route, leave me out....lol
I swear I've taken that engine's sleeping bag on and off a hundred times so far.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go! |
Any chance your oil pickup got bent in shipping? I can't imagine how else you got here.
All 911 oil pumps have a similar pickup location so it not a case of "wrong" part.
Tomorrow I can check carefully to see if it is at all "tilted" with respect to the case. EDIT: This photo seems to show it is quite straight. A bend would leave it tilted.
For thin flange heat boxes, it looks like the new studs are too long, made for thick flange heat boxes.
Bruce |
Actually the pickup tube is fairly fragile. It could easily be bent in shipping.
The alternative is that the pickup tube was manufactured improperly. Given that the tube is furnace brazed to a flat flange, it is probable made in a jig. The thing about a jig is they are fairly consistent. It is possible that the venturi was brazed incorrect to the tube but same situation applies. Probably a jig. If you get to the point where you take the engine apart, I can supply a factory pickup to replace yours. Do you know about the largest river in North Africa?
It's a 914 ...
The challenge you'll have even if you manage to re-shape the screen enough, is that you've only got ~7 mm of screen to venturi gap to play with, which is less than the ~.4" sump plate gap you need to make up to get it to seat on the case. The venturi will be essentially touching the sump plate and there won't be enough space for the pump to properly scavenge the oil. Damn.
The 3 mm is from the venturi to case. With the plates on: The curved plate w/out oil plug I've got now gives me about 3 mm gap, and the curved plate w/ oil plug looks like around 7 mm. So we really can't give up much screen deformation (even if we could do that safely) before we hit the 6 mm gap minimum.
PM emailed back:
Our sump plate is roughly 13.5mm deep, a little over 1/2". These were designed and made for the exact type of application you are referring to, as we often use the newer style or GT3 style oil pump in many of our engine builds.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go! Last edited by OsoMoore; 11-03-2025 at 08:20 AM.. |
It's a 914 ...
Looks promising. How much deeper is that than the plates you already have? Sorry if I missed that measurement in your previous posts. I think the stamped steel plates might be like 1/4" deep? From your measurements, you need an additional .4" depth compared to you already have.
The current plates I've got are curved and shallower, and have more curve than the oil pump screen.
It's a 914 ...
OK, I may have misunderstood your measurements in the earlier post. If your screen is .4" and the new sump plate option is .5", it sounds like a good fit with ~.1" clearance. On the motor I'm building (SC case, 930 pump), the stock plate has about that amount of clearance.
That thought doesn’t work because the cases are all the same casting, Carrera and turbo.
Bruce |
