Try not, Do or Do not
ITB is not in our wheelhouse so your expert input based on actual experience is invaluable.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
One of the very first versions of Richard Clewett's ITBs on a 2.7 RS replica built by Supertec. Easy to use, great performance.
Standard Competition Motors, Berkeley Heights, NJ | Maxxecu engine management and Plex tuning calibration specialist and supplier | chassis dyno tuning and calibration consultations http://www.instagram.com/standard_competition_motors |
Some people might find this to be the "best"!
3.5 EFI using RSR high butterfly built by Ruff for Jerry Seinfeld. ![]() ![]()
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 10-09-2025 at 03:37 PM.. |
Last option is to convert the existing 9M to a DBW but I'd still be out of idle air control monitoring throught the ECU
You do not need Idle air control with DBW. You can use the ECU to open the throttle to get what ever Idle you want. John |
Constitutional Liberal
My experience with EFI is so limited that I wouldn't begin to understand issues with the 9M system but if you can figure out what is missing, mitigating the issues by modifying what you own seems reasonable. Throwing money at a problem is rarely the "best" way to proceed. General rule, not aimed at you John. I am agreeing with your suggestion.
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
For anyone looking for a cost effective forey into the ITB world, I have a stellar set of 50mm PMO ITB for sale. These will fit any size 911 but probably should be used on a 3.0 and larger.
https://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1184687-quick-sale-stellar-set-pmo-50-mm-itbs.html These ITBs tend to give you project a more "period correct" aesthetics and still offer the modern convenience of programmable induction. You can even use a factory early 811 air filter housing to maintain an even more authentic aesthetic.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 10-11-2025 at 06:07 AM.. |
Here's another exciting option I stumbled across in my research.
This system is remarkably similar to the fuel delivery system used on some the NPTI GTP cars of the late 80s / early 90s. I only know this because I owned 11 of the GTP engines as well as one of the cars.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 10-11-2025 at 11:10 AM.. |
Another consideration is length of intake...
Graph of harmonics for various intake lengths. Length is total length of intake; top of stack to back of intake valve. A cut of dyno graphs with an intake manifold and straight velocity stacks, a reference stack length, then adding to it in approx 1" increments. ![]()
Navin Johnson
Years ago we built a 3.8 using dual staged injectors with Haltech EFI. The intake, ITBs, intercooler, headers were all sourced from MODE
The engine made impressive power.. I have other pictures ..... somewhere.... ![]()
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Navin Johnson
This has been interesting to read. Some really good ideas and comments about what has been done in the past. All good info to take in. What has worked is really good to know.
Project 24 includes an new ITB system. Too early to say or show what it is. We have tested both Barrels and Butterfly types on the flow bench. The Barrels certainly show better flow and speed once opened fully but the Butterflies still beat out the Barrels at part throttle. Just turning the air twice I assume is the issue. Our magnesium based 911 Project 24 is all about weight, engine speed and acceleration so air volume and speed are major factors. Anything not needed is removed, anything that can be made thinner and stronger is, the goal is to see how light we can make this engine. Cost is not the driver in this project, weight is. Hopefully some of these weight saving ideas can used by others in the future. |
Henry - this car is on auction now and listed with a "3.4" - do you know the bore and the stroke that RUF used?
Also - what do you think of the exhaust on this car? Thank you Steve Quote:
Half of the exhaust looks great, the primary half uses a flat collector and I'm not a fan. With this engine, I would prefer to use a header system with shorter primaries. Something more like these.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 10-14-2025 at 12:44 PM.. |
Well we couldnt get the old ITB's to sync correctly and were just throwing man hours / dollars out the window so decided to go ahead and upgrade the ITB's now. I went the AT Power & DBW route. My M130 will only drive one DBW motor so it ruled out Kinsler... Now just waiting for these things to show up so we can continue the the build. Thanks all for the recommendations/help!
Robert Guerena 992 GT3 1970 ST 3.2 Hot Rod 1974 RSR 3.8 Backdated |
Pretty sure you will be very happy with the AT Power. Pls update your progress.
Always learning. www.aircooledporsches.com.au |
Interesting - I was told otherwise but good to know.
Racer
The M130 does support driving 2 DBW servos. The problem is that you would be pushing the power limits of the M130 doing so. An M150 is a far better choice when you use DBW because it has more power available and has a lot more outputs and inputs.
The nice thing about upgrading to the M150 from the M130 is that second connector on the M150 matches the one connector on the M130. So upgrades are simple…plug and play. The Kinsler servos are fantastic. Only professional teams don’t balk at the price. I went with two EFI Hardware servos and they performed flawlessly. We (Oscar Zelaya) could not get the AT Power single servo setup to work.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
