What oil pump to use on the 67S rebuild?
The original one looks fair, there's some scratch marks on the impellers (is this bad?) and a little bit of play when turning it (i.e. the impellers will click a bit as it rotates).
What I'd really like to know though, is there a better pump that requires no case modifications, and if so, how do I identify these as I'll probably be looking for a used one. Thanks, Bill
Current: 1975 911S --Chocolate brown
Past:
1967 911S --Bahama Yellow
1990 C2 Targa --Silver
1973 914 2.0 --Delphi Green
Old 10-29-2004, 10:49 AM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
Bill, go ahead and try to find a 76-83 style, usually referred to as the SC pump, or get the later Carrera 3.2 pump. Both fit right in, but with the carrera pump you will have to get a new sump plate with no drain plug... Do the oil bypass modification while you're at it...
Best! Scott
Scott Kinder
kindersport @ gmail.com
Old 10-29-2004, 08:37 PM
126coupe's Avatar
I use the carrera pump in my 2 race engines, dont forget the oil bypass mod.
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 11-01-2004, 07:31 AM
