964 Valve Cover Sealant?
I'm getting ready to do a valve adjustment on my 964. What's the best sealant to use on the inside of the valve covers for hopefully a leak free seal? Curil T?
Thanks in advance,
Dan
Old 01-22-2009, 10:28 AM
idc1873
coxy's Avatar
i use the race formula.
http://www.hylomar-usa.com/_resources/_html/products.html
Old 01-22-2009, 11:04 AM
Thanks Coxy. How hard is it to clean up afterwards when you need to put on another set of gaskets?
Old 01-22-2009, 12:05 PM
idc1873
coxy's Avatar
Pretty easy, there is also a solvent spavailable specificaly for this job.
Hylomar Gasket Remover
Old 01-22-2009, 11:08 PM
Really appreciate the help.
Dan
Old 01-23-2009, 03:35 AM
Manassas, VA
lucittm's Avatar
Why not use the silicone gaskets that our host sells? You can re-use them and the forum seems happy with them.
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 01-23-2009, 09:55 AM
Try not, Do or Do not
Henry Schmidt's Avatar
964 valve covers use an o-ring style seal, so no sealant is necessary. If they leak there is something wrong.
BTW: If you have Curil T there is no need to buy Hylomar. The products are almost identical.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-23-2009, 10:08 AM
Mark, pretty sure during my search on Pelican that they don't make the silicon gaskets for the 964?
Henry, I didn't realize the the gaskets were O ring type. I haven't taken it apart yet. I was looking for some kind of sealant to hold the gaskets in their place while I put the valve covers on. Apparently its not needed. Any kind of tricks to tightening the valve covers down? I believe the book says 6 lbs. I have a torque wrench but really don't trust it with such small increments.
Thanks,
Dan
Old 01-23-2009, 10:32 AM
