Question What is piston ring end clearance ?
The spec book specifies (among other things) this clearance. It is measured pretty much at the "level" where the cylinder meets the crankcase.
Thanks...
P.S. I think Piston Ring Side Clearance = gap between ring land & rings?
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 01-30-2006, 03:01 PM
You are correct about the side clearance. The ring end gap is the "hole" that is left between the ends of the ring when it is in the cylinder bore. It is measured with a feeler guage. The ring must be square in the cylinder to get an accurate reading. I put the rings in near the top of the cylinder where the maximum wear is to see if the rings are still in spec. If you are using new rings then you should check them further down to make sure they are not too tight where the cylinder is not as worn.
-Andy
Old 01-30-2006, 10:23 PM
Hi Andy, thanks for the response.
A few more questions just to be sure: Do you put the ring in without the pistons? And it is the gap between the hole in the ring after its compressed & put inside the cylinder?
Thanks...
Old 01-31-2006, 08:01 AM
Wo ist die Rennstrecke?
DonE's Avatar
Place the ring in the cylinder without the piston. Take the piston, using the top, and push the ring into the cylider to the depth you want, then measure the end clearance (gap).
Old 01-31-2006, 08:32 AM
Less brakes, more gas!
euro911sc's Avatar
Use lube/oil to make things slide easily?
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 01-31-2006, 09:45 AM
Super Moderator
cstreit's Avatar
Yep...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-31-2006, 12:37 PM
Thanks for the explanation folks...
Old 01-31-2006, 01:14 PM
using the piston to push the ring in may not work if your piston has a funny dome like the CIS pistons. The dome will push the ring crooked and give a false reading.
-Andy
DonE's Avatar
Since he has a 930, this shouldn't be a problem. However, you are correct otherwise.
Old 01-31-2006, 05:34 PM
