Try not, Do or Do not
Henry Schmidt's Avatar
Originally Posted by Porschekid962 View Post
Those pictures that Henry post truly are scary but its not like I have not seen that sort of fix before. In racing as long as it lasts the race you are golden, on a streetcar its a bit different. .....edit........
This was not a track side repair. Strangely enough, this was a fresh build with zero miles.
The builder, although regarded as an expert by some, hasn't got a clue!!!
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-24-2008, 04:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #101 (permalink)
Will DC 111 be okay on the cam shaft end cover o rings or will this cause problems?
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 09-24-2008, 05:58 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #102 (permalink)
That is the proper product for those o-rings. Use sparingly and don't let it get on the green gaskets underneith.
-Andy
Old 09-24-2008, 07:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #103 (permalink)
Thanks, that's good to hear since already used it. I used it very sparingly and it seemed to make them slide in easier.
Buck
'88 Coupe, '87 Cab,
Old 09-24-2008, 08:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #104 (permalink)
whackit's Avatar
Also, in the above pic, what is the red sealant in the bearing races? I cant tell if it's lube on the bearings, or if the bearings are being glued in.
That's red line assembly lube.
1971 911E 2.7RS interpretation -- Signal Orange baby!
Old 09-24-2008, 09:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #105 (permalink)
haycait911's Avatar
I'm getting ready to assemble my bottom end. I picked up the sealants and I've been experimenting with the threebond 1194 ( previously 1104). when spread thinly on aluminum, in my garage ( coolish), it sets up to tack free in about 3 minutes. tops! I have concerns about getting it applied and assembling the case in that kind of time frame. any thoughts/input? thanks, Don.
ps - as this obviously isn't anaerobic, will dried squeeze out on the inside harm anything?
Old 10-12-2008, 12:06 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #106 (permalink)
whackit's Avatar
it seems to dry over pretty quickly but when you torque it down it grabs. it took me about five minutes to get it applied to my case. you don't need to use too much, that will minimize squeeze out. I found that loading a syringe and spreading a consistent bead, then smoothing with a foam (not cotton!) swab worked well. The resulting bead is minor and pretty tough, I doubt any would flake off. If you are using the 1211 on the nose you really only need a very light coat, almost as light as you can spread it with a finger.
Old 10-13-2008, 04:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #107 (permalink)
Where can you get Curil T in Canada?
In my province, there seems to be no supplier of Curil T. What is a suitable substitute?
71 911T/2.7
Old 10-13-2008, 09:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #108 (permalink)
Hylomar® Universal Blue sealant
Henry Schmidt
Ph: 760-728-3062
Old 10-13-2008, 09:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #109 (permalink)
haycait911's Avatar
look at my last post here.
http://forums.pelicanparts.com/showthread.php?t=433441
apparently, hylomar by permatex will also work. Don.
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #110 (permalink)
I use non-hardening permatex. It's a black tar-like substance.
-Andy
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #111 (permalink)
iamchappy's Avatar
oil leaks from heads
Here are some underside pictures of the heads where oil is leaking from engine ( same on both sides), i cleaned the engine area up with some brake cleaner because everything was very wet with oil , this may help all of you pinpoint and identify the problem area better . The engine now has about 400 miles on it, the engine builder has tried twice to seal it up without success, he claims that i will probably have to live with the leaks as it is probably a case of parts that dont fit well together. I plan on dropping the engine soon to do a valve adjustment and clutch, pressure plate upgrade.
Is it possible the shop didn't torque the headstuds properly, and if this is the case, could a re-torque remedy the problem, or will things have to come apart again.
Any suggestions.
79 SC heads, 91 turbo 3.3 pistons and cylinders, Supertec head studs. .8 bar boost.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 10-27-2008, 09:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #112 (permalink)
sww914's Avatar
Chappy, did they install RSR "O" rings on the rocker shafts?
Old 10-27-2008, 09:13 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #113 (permalink)
resident samsquamch
sand_man's Avatar
Case through-bolts, perhaps?
EDIT: doubtful, just looked at the pictures again.
-jeff
Old 10-27-2008, 09:14 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #114 (permalink)
mca mca is offline
mca's Avatar
+1
If you pull your valve covers you will be able to see of the rocker shafts are leaking. Without the RSR o-rings, rebuilt engines are likely to leak here according to Wayne's rebuild book.
I used the o-rings and my number 3 exhaust rocker shaft is weeping - was slightly wet. Without the o-ring, it would probably be leaking quite a bit.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 10-27-2008, 09:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #115 (permalink)
iamchappy's Avatar
I dont know what they used for o rings. I but i am assuming they used ones for an SC.
87 924S
Lexus SC400
Lexus LS400
Old 10-27-2008, 09:51 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #116 (permalink)
mca mca is offline
mca's Avatar
The SCs didn't come with them.
If you have seen picks of the rocker shaft you will see two grooves in them. The o-rings fit into these grooves to help seal the shaft. Normally, torquing the shaft will cause them to expand and seal. However, on a rebuilt engine it becomes less likely that they will form the proper seal - hence the o-rings.
Old 10-27-2008, 09:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #117 (permalink)
Forced Induction Junkie
WERK I's Avatar
Any suggestions.
I noticed you're using the '91 cylinders on your build. I have the same type of cylinders on my 3.3 w/3.3 heads. They're weeping between the head and cylinder. These cylinders have a habit of leaking (slightly), mostly due to the amount of surface area between the head and cylinder. I had a post on this site as to what can be done to remedy. Steve@Rennsport replied there's not much that can be done except to disassemble and and have the heads and cylinders ringed. He stated he's done this many times on these cylinders with fantastic results.
To rule out the rocker shafts, I pretty much used the ol' white glove technique. Use a white glove or white cloth and touch the ares outside the rocker shaft. If there's oil, it will show.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 10-27-2008, 10:24 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #118 (permalink)
iamchappy's Avatar
My leaks are leaking more than slightly, i could never drive it around for a day, and forget about using the heater boxes, after driving the car for a half hour or so the bottom and engine case are very wet and drippy.
87 924S
Lexus SC400
Lexus LS400
Old 10-27-2008, 10:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #119 (permalink)
WERK I's Avatar
did you use the green viton o-rings that go in the spigot bores of the C2 930 cylinders?
Dave
Old 10-27-2008, 11:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #120 (permalink)
