Try not, Do or Do not
The builder, although regarded as an expert by some, hasn't got a clue!!!
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Will DC 111 be okay on the cam shaft end cover o rings or will this cause problems?
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
That is the proper product for those o-rings. Use sparingly and don't let it get on the green gaskets underneith.
-Andy
72 Carrera RS replica, Spec 911 racer |
Thanks, that's good to hear since already used it
. I used it very sparingly and it seemed to make them slide in easier.
1971 911E 2.7RS interpretation -- Signal Orange baby! |
I'm getting ready to assemble my bottom end. I picked up the sealants and I've been experimenting with the threebond 1194 ( previously 1104). when spread thinly on aluminum, in my garage ( coolish), it sets up to tack free in about 3 minutes. tops! I have concerns about getting it applied and assembling the case in that kind of time frame. any thoughts/input? thanks, Don.
ps - as this obviously isn't anaerobic, will dried squeeze out on the inside harm anything? Last edited by haycait911; 10-12-2008 at 12:23 AM.. |
it seems to dry over pretty quickly but when you torque it down it grabs. it took me about five minutes to get it applied to my case. you don't need to use too much, that will minimize squeeze out. I found that loading a syringe and spreading a consistent bead, then smoothing with a foam (not cotton!) swab worked well. The resulting bead is minor and pretty tough, I doubt any would flake off. If you are using the 1211 on the nose you really only need a very light coat, almost as light as you can spread it with a finger.
Where can you get Curil T in Canada?
In my province, there seems to be no supplier of Curil T. What is a suitable substitute?
71 911T/2.7 |
Hylomar® Universal Blue sealant
look at my last post here. http://forums.pelicanparts.com/showthread.php?t=433441 apparently, hylomar by permatex will also work. Don. |
I use non-hardening permatex. It's a black tar-like substance.
-Andy
oil leaks from heads
Here are some underside pictures of the heads where oil is leaking from engine ( same on both sides), i cleaned the engine area up with some brake cleaner because everything was very wet with oil , this may help all of you pinpoint and identify the problem area better . The engine now has about 400 miles on it, the engine builder has tried twice to seal it up without success, he claims that i will probably have to live with the leaks as it is probably a case of parts that dont fit well together. I plan on dropping the engine soon to do a valve adjustment and clutch, pressure plate upgrade.
Is it possible the shop didn't torque the headstuds properly, and if this is the case, could a re-torque remedy the problem, or will things have to come apart again. Any suggestions. 79 SC heads, 91 turbo 3.3 pistons and cylinders, Supertec head studs. .8 bar boost. ![]() ![]()
![]() 914 6 Turbo twinplug 3.12 87 924S Lexus SC400 Lexus LS400 |
Chappy, did they install RSR "O" rings on the rocker shafts?
resident samsquamch
Case through-bolts, perhaps?
EDIT: doubtful, just looked at the pictures again.
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
+1
If you pull your valve covers you will be able to see of the rocker shafts are leaking. Without the RSR o-rings, rebuilt engines are likely to leak here according to Wayne's rebuild book. I used the o-rings and my number 3 exhaust rocker shaft is weeping - was slightly wet. Without the o-ring, it would probably be leaking quite a bit.
82 911SC Coupe Chiffon / Chocolate 9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD) |
I dont know what they used for o rings. I but i am assuming they used ones for an SC.
If you have seen picks of the rocker shaft you will see two grooves in them. The o-rings fit into these grooves to help seal the shaft. Normally, torquing the shaft will cause them to expand and seal. However, on a rebuilt engine it becomes less likely that they will form the proper seal - hence the o-rings.
Forced Induction Junkie
To rule out the rocker shafts, I pretty much used the ol' white glove technique. Use a white glove or white cloth and touch the ares outside the rocker shaft. If there's oil, it will show.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
My leaks are leaking more than slightly, i could never drive it around for a day, and forget about using the heater boxes, after driving the car for a half hour or so the bottom and engine case are very wet and drippy.
did you use the green viton o-rings that go in the spigot bores of the C2 930 cylinders?
