Originally Posted by Alan L View Post
Have you tried discussing the fix with Steve Rassmo - he is usually quite helpful and knowledgeable.
Yes, the shipping costs ex US often double the price of the item, but the supply of bits is unbeateable.
Alan
Yes, Steve R is helping from the sidelines. It was an OPC full rebuild and he supplies them so is cautious with attribution of 'blame' but is helping on the technical aspects. It was him that told me it's only truly fixable with a reseal.
Old 02-26-2017, 03:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #521 (permalink)
My friend Peter Booth at https://www.motorscience.co.nz can help you invert your Photo and your car.
regards
Old 02-26-2017, 04:40 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #522 (permalink)
regards
Haha, it looked fine on my iPad Safari browser. Just looked at it on my pc and can see what the comments were about. I suspect it's based on my being left handed and the consequent iPhone orientation. Evidently only iOs is able to compensate.
Old 02-26-2017, 10:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #523 (permalink)
Benny Hill used to have a segment on his show from the U.K. that went "and now from Austraila)
and they would invert the camera.
regards
Old 02-27-2017, 07:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #524 (permalink)
Originally Posted by Henry Schmidt View Post
No worries, we have a huge inventory on these kinds of ancillary parts.
If the cover really require a sealant I would use Dow 55 and LocTite 574 on the perimeter making certain not the get it on the o-ring. In the alternative, 1211 can be used to seal the o-ring.
In this application it's important not to use a lubricant that will cause wicking.
The first page of this thread specifies Dow 111 for O rings. Is Dow 55 a general substitute for Dow 111 or is Dow 55 specific to this application?
Old 03-08-2017, 01:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #525 (permalink)
Try not, Do or Do not
Henry Schmidt's Avatar
I can't speak intelligently about Dow 111 because we don't use it.
We chose Dow 55 because of it's military application (testing and continued use). We buy it as military surplus because when we started using it, Dow 55 was not available in retail packaging.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-08-2017, 09:18 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #526 (permalink)
Thanks Henry.
Old 03-08-2017, 01:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #527 (permalink)
Member 911 Anonymous
DRACO A5OG's Avatar
I think I missed it, but does anyone know how fast 1184 cures?
I am wondering if I should apply the 574 on saddles first or the 1184 on the perimeter first?
TIA,
Jim
'85 Carrera Targa
PCA/POC
Old 03-11-2017, 06:03 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #528 (permalink)
arbita1's Avatar
TIA,
Jim
I think I did 574 first. The 1184 skims over pretty fast.
Matt.
83 911SC
85.5 944 NA - Sold
Old 03-12-2017, 04:36 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #529 (permalink)
TIA,
Jim
The 574 is an anaerobic sealant (dries in the absence of air/O2) so apply it first. It won't start to harden until you clamp the case halves together.
Henry Schmidt
Ph: 760-728-3062
Old 03-12-2017, 10:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #530 (permalink)
DRACO A5OG's Avatar
Thank you sirs :-)
BTW, how does one keep the 1184 from squeezing into the case? I did a couple of test runs and boy the 1184 really squeezes out allot.
I am not wrried about the 574 but do worry about silicon getting inside the case.
'85 Carrera Targa
PCA/POC
Old 03-12-2017, 12:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #531 (permalink)
DRACO A5OG's Avatar
Wtd
Noticed the case thru holes only have chamfers on nut side
No wonder the old orings were crushed and ripped on one side
Should I chamfer the Bolt side?
Old 03-12-2017, 03:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #532 (permalink)
abit off center
cgarr's Avatar
Check the washers, as I remember half of them should have a chamfer and those go on the side of the case without a chamfer and the others should be flat?
______________________
Craig
G2Performance
Old 03-12-2017, 03:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #533 (permalink)
VFR750's Avatar
Chamfer the holes. Use chamfered washers. Orings will be happy
Old 03-12-2017, 03:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #534 (permalink)
DRACO A5OG's Avatar
Thank you Brothers
Yes all the washers are chamfered type
Will be chamfering/deburring the d-side case thru holes
Using this type of tool http://www.noga.com/pdfFiles/coun.pdf
Old 03-12-2017, 04:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #535 (permalink)
"BTW, how does one keep the 1184 from squeezing into the case? I did a couple of test runs and boy the 1184 really squeezes out allot.
I am not wrried about the 574 but do worry about silicon getting inside the case. "
You just need a very thin coat but you want some squeeze out. The 1184 is not silicone RTV and it is semi-hardening and remains elastic so it doesn't break off like the silicone RTV does. It's the same stuff used to seal motorcycle cases, also sold as Hondabond 4, Yamabond, Suzukibond 4, etc. it's good stuff.
Old 03-13-2017, 06:56 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #536 (permalink)
DRACO A5OG's Avatar
Good Stuff, Nice :-), better use the acid brush, painter putty knife leaves too thick of a coat.
One more, is it okay to have the 574 and 1184 contact each other, like bottom of the #1 and top of #7 bearing areas?
TIA,
Jim
'85 Carrera Targa
PCA/POC
Old 03-13-2017, 08:31 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #537 (permalink)
That won't hurt anything.
Old 03-13-2017, 12:56 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #538 (permalink)
DRACO A5OG's Avatar
Throttle Body to Intake, SEALANT or DRY?
Hey Fellas,
Besides using the new back O-ring in the Wrigtwood Kit, I assume no sealant but just want to make sure. Does anyone happen to know the torque specs for the four allen bolts
TIA,
Jim
'85 Carrera Targa
PCA/POC
Old 04-03-2017, 12:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #539 (permalink)
DRACO A5OG's Avatar
Answered my own question:
No sealant just new O-ring
Torque Specs, anyone anyone?
'85 Carrera Targa
PCA/POC
Old 04-04-2017, 12:14 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #540 (permalink)
