-   911 Engine Rebuilding Forum (http://forums.pelicanparts.com/forumdisplay.php?f=257)
-   -   Distributor bung (http://forums.pelicanparts.com/showthread.php?t=451103)
quint22cp 01-13-2009 11:44 AM
Distributor bung
Hi allSmileWavy
I have fitted a direct fire ignition system to my 1988 coupe and no longer require the distributor, so I want to remove it and bung up the hole. Does anyone have a drawing of an aluminum bung that I can machine up to do this job?
I know I can pull out the dizzy and measure it all up and make one but that means taking the car off the road for a couple of days:(:(:(
safe 01-14-2009 11:32 AM
Originally Posted by quint22cp (Post 4415129)
Hi allSmileWavy
Make me one too!! ;)
http://forums.pelicanparts.com/uploa...1231961472.jpg
http://forums.pelicanparts.com/uploa...1231961494.jpg
JohnJL 01-14-2009 02:44 PM
I think Smart or JB racing sells them. Works well but be sure to lube up the o-ring (hehehe) or else you won't be able to remove it without splitting the case.
You dont need to take it off the road, just measure the outside diameter of the distributor and re-install it.
If you do make your own you might weld/machine a loop or hook on it for easier removal.
Dennis Kalma 01-14-2009 03:55 PM
Make me one too...but I don't want to have anything outside the distributor hole, meaning no need to bolt it to the adjustment stop bolt. Just a bung that is locked somehow in place.
I have thought and had the idea to glue it in (using a loctite of some sort) and then drill two small holes in the case at the bung location to pin it in for sure.
Likely overkill....
Dennis
JohnJL 01-14-2009 04:33 PM
Sorry, its Clewett that makes and sells them....page 6 of the catalog...http://www.clewett.com/products/catalog.pdf
$64.00
quint22cp 01-15-2009 10:44 AM
Thanks for all the replies and photos.
I will knock a couple up, maybe with a threaded blind hole so I can screw in a bolt if I need to pull it out.
PM me your address and I will post you one when I find out what works best.:)
rsscotty 01-15-2009 12:04 PM
Distributor plug
This is a picture of a factory plug. The engine is a 993 GT2. Same 30mm hole in case. The plug as I remember had a 996 part number on it.
http://forums.pelicanparts.com/uploa...1232049810.jpg
quint22cp 01-18-2009 09:02 AM
Well here's how it came out:)
http://forums.pelicanparts.com/uploa...1232298071.jpg
cgarr 01-18-2009 10:56 AM
nice! Myford lathe?
