mykle57's Avatar
Oil cooler pressure check
I'm looking to have my oil cooler pressure tested and cleaned up.
Could someone give me a suggestion of a shop that would be able to do this and about how much I should expect it to cost? It's on a '77 911s. And I'm in Massachusetts. Some place close by would be nice.
Last time it was running it was leaking a bit and since I've dropped the engine an pulled off the cover to find it was stuffed with leaves, twigs and acorn shells. I haven't pulled the cooler off yet to check the seals, but, thought I better go ahead and get it checked-out.
Old 10-20-2010, 06:02 PM
If you want it pressure tested, I have this and an external cleaning solution.
Bruce
Old 10-21-2010, 02:02 PM
pete3799's Avatar
I made a pressure tester you could borrow.
Unfortunetly i'm on my way to GA. right now but if your not in a hurry i could send it to you late
next week when i'm back home.
Pete
79 911SC RoW
Old 10-21-2010, 05:16 PM
Call a small aircraft repair shop at your local airport. They should be able to direct you to a shop able to clean test and repair if needed. I think there is an ultrsonic cleaning process. If engine has not experienced a blow up and there is unlikely any trash in it then a rad shop should be able to pressure test it.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 10-21-2010, 06:06 PM
My friends call me Phish
I have used two different places, but they are in California
But if your interested.
Pacific Oil Cooler Service, Inc. - Home
for repairs, test, and cleaning
and
Ultra Sonic Cleaning - Carson, CA
$40 for test and cleaning
310-327-8930
Old 10-22-2010, 08:18 AM
I can pressure test your cooler and provide a replacement leak free cooler if needed.
I am in CT near Hartford.
PM me for details
Tom Butler
1973 RSR Clone
1970 911E
914-6 GT Recreation in Process
Old 10-22-2010, 12:27 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Critical Operations Inc.
(714) 258-8544
1707 Boyd St
Santa Ana, CA 92705
Bill can pressure test and sonic clean your cooler for a very reasonable price with extremely quick turn-around.
They also do nondestructive critical analysis for high performance parts.
They do all of our x-ray work. Titanium parts, rods, valves and so on.
They can also manufacture small run machine parts.
Bill's a good guy too.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-23-2010, 10:02 AM
bavaria911's Avatar
Henry-
Thanks for the firms name and contact data. I will be sending my oil cooler to them after calling on Monday.
Vr,
Scott
Bavaria911
1970 911T w/ 2.4S
1971 911T Targa w/ 2.2
RG Member # 818
Old 10-23-2010, 07:58 PM
Sorry to hyjack this thread but has anyone tried the replacement coolers our host sells? I've gone through 3 coolers in the last 5 years. I'd like to try a new one but don't want to cough up 1500 bucks. Right now I have my cooler blocked off and am just using the front bumper cooler. It works ok but track temps are a little high.
-Andy
Old 10-23-2010, 08:34 PM
mykle57's Avatar
Back to Porsche projects.... Thank you to all who responded.
Was able to borrow a pressure tester and try it out. My cooler doesn't hold any pressure for more than a few minutes. I can also hear the faint sound of air hissing out.
And before you ask, yes, I did make sure that the hissing didn't come from the seals. :-)
Just to be sure I dunked the whole thing in a bucket of water and could see at least two spots on the fins where bubbles were streaming out. I guess that means this thing is toast.
Read a bunch of threads here from folks who have had their cooler repaired; some good some not so good. Our host has them priced at only $1250. I guess that means I'm going to be looking for a used replacement. Or would those in the know tell me avoid the headache and get the new one?
Old 11-10-2010, 12:29 PM
pete3799's Avatar
PM me for details
I bought one from Tom. Couldn't be happier.
Send him a PM.
Pete
79 911SC RoW
Old 11-10-2010, 01:47 PM
911 tweaks's Avatar
mykle57...I sent you a pm earlier this afternoon...check it out & let me know...
Bob
I live for 911 tweaks...
Old 11-10-2010, 02:38 PM
Grand Am/IMSA Data Guy
Porsche84's Avatar
1+ for Pacific Oil cooler
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 11-10-2010, 03:10 PM
