porscheboy1
Crankshaft tolerances.
Hi guys. I am restoring a 1978 911 SC and it is time to stare re-assembling the engine. I miked all the journals on the crank shaft and they are right at the bottom of the allowable limit. The Bently manual states for the lower limit 2.3611 for the mains and I have for the six mains +.0003, +.0001, +.0002, .0000, +.0002 and -.0001 above and below that limit. On the rods the Bently manual states for the lower limit 2.0855 for the rods and I have for the six rods .0000, +.0002, -.0001, -.0001. -.0001,.0000 and -.0001 above and below that limit. All the journals are round and have no grooves worn in them that I can see or feel. Could I polish them a bit with some fine crokus cloth and put in a new set of srandard bearings? Are there available beasings a few ten thousands over size? If I need a regrind to whom could I send the shaft that can give it the proper heat treatment to bring back the required hardness. Thanks, John
1964 356 SC
1978 911 SC
1982 911 SC
Old 12-06-2012, 02:32 PM
Here is a typical inspection report for a 3.0 crank. All dimensions in mm.
Note that the wear limit is the min diameter allowable for rebuild. The limits in the Bentley manual are limits for a new unused crank.
Tom Butler
1973 RSR Clone
1970 911E
914-6 GT Recreation in Process
Old 12-06-2012, 05:42 PM
crank
John, send your crank to Armando at CCR in Ca. he has done all my 911 cranks for years, If you are at the lower limits and round I would have him verify that, pull the galley plugs, clean it and if needed heat treat the crank and it will grow a few tenth's and look at the clearances with factory bearings and also you can coat the bearings and gain .0004 per shell, crossdrill the # 4 journal and groove that bearing as well.
Mike Bruns JBRacing.com
CCR 650 342 0568
Tell him I sent you
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 12-06-2012, 05:43 PM
porscheboy1
Gentlemen, Thanks much for the information. I'll convert my readings to metric, my micrometers are in inches, and check it out.
Regards,
John
Old 12-06-2012, 06:47 PM
A tenth is pretty damn small; are you verifying your mic against a known-good standard before measuring?
'90C4
Old 12-07-2012, 05:26 AM
porscheboy1
A standard bar came with the micrometer and I check it often and zero the mic if necessary. I practised a lot and am able to ger consistent readings. I also had a machineist double check me on a couple of the journels.
Old 12-07-2012, 11:25 AM
AlfonsoR's Avatar
If your mics are of high quality, then you can trust the standards. Otherwise, if questioning a few tenths of a mil, it's worth a few dollars to have someone else inspect it. Heck, even if you have nice mics, it's still worth to get a second hand reading before you spend another chunk of money.
Old 12-12-2012, 09:26 AM
