3.0 SC engine bearing numbers
Finally got down to the bearing level in my 1980 3.0 SC engine. The rod bearings have the number 930-148-00 on the back of the bearing shell and the main bearings have the number 930-132-02 on the back of the bearing shell. According to my measurements, these appear to be standard size bearings and it appears that the crankshaft is still within standard tolerances for the mains and rod journals. Looking thru the PP parts list, the Rod bearings are now listed under the number 930-103-148-00 and the Main bearings are listed under the part number 964-101-901-00-M41. Am I correct in believing that these are the bearings that I need for my engine?
Thks, |
Not going with GT3 bearings?
Todd |
| All times are GMT -8. The time now is 02:33 PM. |
