930 engine with JE 97 mm piston ring?
Hi
I am rebuild 930 engine with JE 97 mm compress ratio 8.5, can I use Goetze (97mm-1.5 X 1.5 X 3.5mm). Need you guys input! Thanks! TIEN |
You have to watch ring depth as well a ring width. Diameter is a given. When in doubt call Jerry @ JE with the piston number. You can generally find it on the wrist pin boss. |
Hi Henry,
Jerry retired from JE after 30+ years and his replacements do not know 911's like he did. |
