sealant for cyl. gaskets
Hate starting new threads all the time, but i need to get going on this motor,.... what sealant should i use for the copper cyl. to case gasket. Waynes book says to use the case sealer, but since i didn't split the case, i don't have any and wonder what else i can use.
Would Yamabond work ?
1987 911 Carrera Coupe 1987 Buick Grand National 1971 Plymouth Roadrunner Last edited by Tori; 04-15-2017 at 07:53 PM.. |
Try not, Do or Do not
Curil T
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Thanks Henry, suppose i'll have to mail order that. Was hoping to find something local and keep trucking with this....
1987 911 Carrera Coupe 1987 Buick Grand National 1971 Plymouth Roadrunner |
I used nothing at all on the copper cyl base gaskets, out of ignorance. Has not leaked a drop since 4 years or so. Maybe not so critical, copper will seal pretty well by itself. Next time I will be using the thinnest layer of curitT
80SC (ex California) |
Curil T is great. I use non hardening permatex because it's available everywhere. I disagree with Wayne's advice on using case sealant. You should use a non hardening sealant because you need the cylinders to seat fully into the case when you torque the headstuds. If you use a hard sealant then it might dry before you finish putting the cylinders and heads on. This would result in variations of cylinder height.
-Andy
72 Carrera RS replica, Spec 911 racer |
The reasoning behind using Curil T is that it is non-hardening. This allows the cylinder to move without disturbing the seal. With heat expansion, the cylinder to case to head joints are constantly moving.
The copper gasket (in a perfect world) should work without additional sealant but with these old engines "perfect" is illusive. We generally put a thin bead of Curil T in the corner of the cylinder where the spigot meets the base. This seals the cylinder to the case rather than coating the gasket. A fine distinction but it seems to work well. It also seems to make more sense when dealing with the 3.6 base o-ring.
