Engine assembly tips...
I've been just about ready to start assembling a 2.7L long block for what seems like months and was thinking about this thread which discusses beveling the backside of the oil supply holes on the main bearings. For a novice like myself, this seems like a generously shared, great tip that's not covered in any of the typically available and utilized resources.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/961695-main-bearing-install-tip.html I'd love to learn about other little tips like this that some of the more experienced builders have picked up over the years. I understand that a lot of this knowledge is hard-won and proprietary and guarded, but any little extra bit that advances reliability or performance I'm sure would benefit more than a few future rebuilds. I'm sure there are a few folks that post here that could write a book... that I would buy! Thanks, Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
Tom,
I've found that all the "important" tips are found in Wayne's book, which I hope you have, but he understates many of them. For example, the biggest tip I could give for building a motor is to ABSOLUTELY use the metal strips that hold the rods up in the air as well as the chain. There is a Porsche tool number associated with these - you can buy them from Baum tools or make them as per Wayne's book. He doesn't really mention in the book that the use of the rod / chain holders is CRITICAL to preventing leaks on the case, but it is. I have assembled many motors; early on, I'd have a second person hold up the rods and pass the chain through the opening. Invariably, minute quantities of Loctite 574 were smudged on the case parting lines which resulted in minor but annoying leaks. Using the chain / rod holders means mating the case surfaces is a one man job but more importantly it removes your fingers from being anywhere near the case parting surfaces and makes it so that the mating and the adhesive is perfect and leak free. Sure, the car will run fine with leaks, but who wants leaks on a brand new build? |
Under the radar
Agreed. Wayne's book has all the info needed to assemble a stock motor. If you are not clear about something, ask it here.
Now if you are building a hot rod or using aftermarket or modified parts, there may be issues to contend with not in Wayne's book.
My build is mostly tried & true 2.7L w/RS P&C's, 964 cam, likely carbs, possibly EFI. Motor will be a nice, durable, drivable street motor, not a high strung race motor - 100% street. Just last week I fabricated a set of the sheet metal strip tools for mating the case halves, using the image w/dimensions in Wayne's book as a guide. Thanks again! Tom
I recommend reading through the "Complete Engine Sealant Thread":
http://forums.pelicanparts.com/911-engine-rebuilding-forum/284737-complete-engine-sealant-thread.html There is some "spirited discussion" in there, but it's a worthwhile read. Lots of tips in there regarding how to avoid leaks on a rebuild. Looking back on my rebuild, my best tips are: - Case prep is important. Verify all your squirters work, all the galleys are clear, no chips, etc. Make sure the case is spotless and everything works before you start assembly. - Plan ahead relentlessly; make checklists for everything and stick to it. Break it down into small assembly steps. Validate the checklist and then do the assembly. Don't get in a rush. Don't take shortcuts. Stop when you have questions and research. It's better to let things sit for a few days while you figure it out than to wake up in the middle of the night wondering if you did something right/wrong. - Keep everything clean, organized, packaged until ready to clean and install, and then do more cleaning. - Definitely upgrade the oil pump and do the case by-pass mod. This is one of the keys to a happy, cool motor. |
Strips look great! Good job!
Chain fence eating turbo
Coming from the guy who is making engine cases from scratch, that is a compliment!
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
Schleprock
I'm no pro and just above a hack. So take my advice with a grain of road salt.
Kevin L '86 Carrera "Larry" |
Pieces of pipe strap work well for holding the chain and 3 of the rods up too.
You can get the other strips of sheet metal at Home Depot. Around here they're used with nails during new house builds to strap down roof trusses to help keep them on during hurricanes. |
Midway down this thread http://forums.pelicanparts.com/911-engine-rebuilding-forum/785959-gordos-3-2l-engine-rebuild-ready-reassemble.html check my post on my homemade chain & piston rod keepers. Make sure the material you used isn't too wide to fit through the case half, or you could find some undue excitement. Gordo
Don "Gordo" Gordon '83 911SC Targa |
1.Do not drink alcohol, smoke weed or take lsd during rebuild.
KTL, those are great tips!!!!
Those should be added to Wayne's book for sure. That is experience talking, as I remember every single thing you said when I rebuilt mine 5 years ago or so.
Yes, thank you for the continued great tip sharing.
This one's pretty easy for me... : ) : ) I'm pretty boring when it comes to all that stuff, which is not a bad thing!
I agree with the others that Wayne's book is a wealth of assembly info. The only thing you might want to seek further opinions on is the suggested use of Loctite on rod bolts/nuts. I recommend against it but I do recommend the use of ARP of similar bolts torqued using a stretch gauge. And that would mean you should get the big end of the rod re-sized to ensure they are round and the correct size.
1986 Targa Guards Red 2021 MT09 SP Last edited by brighton911; 01-26-2018 at 05:03 PM.. |
Thank you for this. I did a practice assembly yesterday, which I originally WASN'T going to do and guess what... glad as he11 I did as my chain holder strip didn't fit through the left case half opening. That would have stressed me out big time if the sealant applied stopwatch had started already... fixed now though! Thanks, Tom
Slippery Slope Expert
1. No silicone seal anywhere. Silicone GREASE on “O” rings, but not SEAL. Si sealant defeats the design purpose of an “O” ring and will make it leak.
2. Have trouble holding onto those slippery rocker shafts when removing or replacing, particularly replacing? Try an electricians fuse puller. Generally plastic so they won’t harm the rocker shaft, curved notches to fit. 3. (The following only works with the engine out of the car and already being disassembled.). Trouble removing rocker shafts? Get some 1/4 inch all-thread that will reach from the rear of the cam housing to #1/#4. With the rocker shaft bolts removed you can run this through the shafts to the difficult one. A small washer will just fit in the shaft bore. Put a small washer and nut on this, then use the rod to pull the shaft. If particularly difficult put a length of small PVC pipe over the all-thread and up against the cam housing, then another washer and nut and use it as a puller. 4. You can also use PVC pipe as a “pusher” to help get tight rocker shafts installed. Again this is only when the engine is dropped.
“As new technologies become indistinguishable from magic, and I can no longer tinker, the magic goes away for me.” |
abides.
I would suggest using a non-liquid assembly lube. I believe Redline and Joe Gibbs both make an assembly grease.
I used Brad Penn assembly lube on my rod and main bearings, and it would drip out of the cylinder spigots when I rotated the engine case during assembly.
Graham 1984 Carrera Targa |
Head intake bolts, which Loctite to use.
Finally putting new PMO 40's on my 2.2 E with S pistons. With the new manifolds came longer intake studs. What Loctite should I used, intake studs to heads. Thanks, Mark
1974, 914-6 GT Tribute 2007 Cayman S 1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten. 2017 Golf Sportwagon 4motion Exclusive source for the 914 Umbrella and Service cover |
Mark the tightening sequence of the case thru-bolts on the case with a Sharpie ( it wipes off easy with a little laquer thinner).
Buy (and use) Stomski's circlip injector tool. It's patented for a reason. I couldn't imagine installing the circlips without it. Last edited by Drbraunsr; 03-23-2018 at 08:27 PM.. |
Booze DOES help when cleaning everything though
![]() Squirt some clean, scrub with brush, swig a beer, repeat. for DAYS.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
