Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
2004, 330ci abs-brake lite air bag lite on
been a year.
seems no one can answer this! amazing.
I completed the Airbag recall but the air bag lite still on. the Gwinnett Georgia dealer are the low rents, wanted $260.00 up to just scope the system. I said No your still the low rents.
I notice some brake pedal hardness months ago after over heating. Water tank split. changed out items. then the lights come on!
i was told on line by another source that if the car got hot you may be having some issues and replace (rebuild) the abs terminal etc I forgot the name!
The wheel sensors cleaned,? new front disc's, etc all done. still lights are on. tried everything. My scanner shows no codes so i suspect you need a special one to do so. I checked the fuses many times, unhooked battery etc. etc, many times.
still lights on/
It passed inspection easily even with the lights on.
Old 05-26-2015, 09:15 AM
