Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
bdjohns (guest)
Guest
Posts: n/a
The solenoid on top of the control valve is getting hot and the car is not running, just with the key on. Is this normal?
This post was auto-generated based upon a question asked on our tech article page here: BMW E46 Heater Valve Replacement | BMW 325i (2001-2005), BMW 325Xi (2001-2005), BMW 325Ci (2001-2006), BMW 325ti (2001-2004) | Pelican Technical Article
Old 02-07-2017, 09:42 AM
Yes, these solenoids are powered closed, so if you have the controls inside the car set to cool, then the solenoid should be powered and will get hot.
- Casey
Thanks for the quick reply. The AC controls were off. Just the key on. I'll watch the new one that is not installed and see how it works with the climate control turned on.
Old 02-07-2017, 01:04 PM
