-   BMW 3-Series E90 (2006-2012) (http://forums.pelicanparts.com/forumdisplay.php?f=276)
-   -   Engine Over Heat Warning. Need Help (http://forums.pelicanparts.com/showthread.php?t=1000475)
Handyjay 06-25-2018 04:55 AM
Just experienced a strange event on a highway trip with 2006 325i with 100,000 miles. Engine temperature warning light came on yellow or orange and in a few seconds went to red. I think the A/C compressor shut off and I lost power(no acceleration). Pulled off and checked coolant, no problem. Engine did not seem over heated. I disconnected battery ground and reconnected thinking that I had a false fault and that would reboot the ECU. Then the tire pressure icon showed up along with "battery". I checked tire pressure and they were only off a pound or two. Balanced tire pressure and reset tire monitor. Drove for a bit and all warnings disappeared. Engine ran as normal for another 90 miles to home with no warnings or problems. What do I need to do? Did I reboot the ECU properly? Thanks in advance for any and all advice.
Dmitry at Pelican Parts 06-29-2018 04:00 PM
Did you try to pull any codes to see if there was an actual fault? I've also had some odd occurrences happen with my 135i that ended up being nothing.
