Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E90 (2006-2012)
components replaced still overheating
335i xdrive 2009, 115,000 miles; Thermostat and pump are new, system bled multiple times and pump is working fine. When engine temp increases, fan comes on as expected. Upper hose is hot; hose to oil filter housing is hot; lower hose and all regions of radiator are ice cold (not even warm). Steam in overflow reservoir when opened. At 210F fan goes to high speed; car goes to limp mode with excess gas consumption. Mild (not hot) heat at heater core when engine temp gets to 200F+. No noticeable leaks; no carbon fumes in coolant fluid. Could this be 1) bad (but new) thermostat, (pump is functioning via bleeding procedure), temp sensor at oil filter housing or something else?
thanks
Old 12-29-2020, 08:00 PM
