Ac compression line ,lower
Does anyone know if there is a compatable part from another car that would work ? Having the hardest time finding one! IT IS PART #
64536927845 It's a hot summer and I need air ,please respond with any ideas. Thanks lisa |
I have a 2008 BMW 328i convertible with 101,000 miles on it and the car will shut off while driving down the road. This is my wife's car so I do not drive it very much. The car had the battery cable replaced in July of 2016 as part of the recall. I am leaning towards the fuel pump because it seems to happen when there is less than a quarter tank of gas. I have been reading a lot threads that are saying the VANOS or camshaft sensors could be the culprit as well. This very frustrating and difficult to diagnose as the problem is intermittent. Any help in this matter would be greatly appreciated
Hi Bitb1,
You should investigate the siphon hose in the fuel tank. It pulls fuel from one side of the tank to the other where the fuel pump is located. Sometimes it can break down or become disconnected and cause a similar symptom. |
| All times are GMT -8. The time now is 10:14 PM. |
