Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E90 (2006-2012)
Jaron (guest)
Guest
Posts: n/a
I looked up the codes for my BMW 328i 2007-
Codes
read on 2/8/17-
2A99-crank shaft exhaust camshaft correlation
read on 2/9/17
2ef4 map thermostat, mechanics
cf- misfire during warm up cylinder 3
29cf misfire cylinder 3
codes read 2/10/17
2A43 valvetronic, thermos overload protection warning threshold
29EO fuel mixture control
29E1 fuel mixture control 2
Based on this info, does it seem likely that I have a feeling spark plug on cylinder three. And possibly a feeling camshaft or crankshaft position sensor? I recently changed my thermostat and water pump on this car with no leaks or issues with coolant.
This post was auto-generated based upon a question asked on our tech article page here: BMW E90 Camshaft Position Sensor Replacement | E91, E92, E93 | Pelican Parts DIY Maintenance Article
Old 02-14-2017, 09:24 AM
Seems like a few different things going on, the cam and crank correlation is likely the root cause of the codes that followed. Have the cam timing checked and then go from there.
- Casey
