Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E90 (2006-2012)
Add Antifreeze
In one month I have poured antifreeze in the reservoir of my '07 BMW 328i. Is that normal? It's not leaking any wherever I park it. What else should i check?
Old 04-29-2017, 04:45 PM
Administrator
Dmitry at Pelican Parts's Avatar
How much have you added? Is the car's thermostat indicating that it's going to overheat? You may have a faulty thermostat if there is no issue. Have the codes read; it'll give you a great place to start. In case you need to replace your thermostat, I've attached a DIY tech article below.
BMW E90 Thermostat Replacement | E91, E92, E93 | Pelican Parts DIY Maintenance Article
Old 05-01-2017, 10:13 AM
