2011 328i X Drive 6 Speed Manual
Last 5 weeks or so, 17 mile drive to work mostly intestate-80 mph speeds. Runs perfectly for morning drive. 17 miles back home afternoon, 80 mph speeds. The very 1st stop light I hit; the rpm's rev to 1100, then slowly return to 600. 5 lights to get home and engine continues to rev rest of way home. Does not, run perfectly...
Salt Lake temperature of course a little cooler in the AM this time of year, but the afternoon temp isn't a huge change (maybe 10-15 degrees most days) Data- Purchased with 30,000, now 72,000 Service light comes on for 50-70 miles, then off for 50-70 miles Codes- P1006, P2096 I pulled out and cleaned the VALNOS solenoids (they looked bran new to me) With this pattern, would you assume I need to tackle the Eccentric sensor? Or is there something else going on? |
Administrator
The P2096 code refers to your fuel mixture being too lean. I would address this issue first and see what difference it makes with the overall drive. If you're needing/going to replace the sensor, take a look at the link below to our site's DIY tech article on the procedure. Hope this helps and best of luck!
https://www.pelicanparts.com/BMW/techarticles/BMW-3-Series-E90/FUEL-Eccentric_Shaft_Position_Sensor_Replacing/FUEL-Eccentric_Shaft_Position_Sensor_Replacing.htm |
Ok rather than start replacing stuff, I had BMW run diagnostics ($150.00). They say replace the ESP Sensor first. I have seen a lot of success stories in this forum and trust its advice. So, do you still think I should tackle the P2096 first?
By the way, if you do suggest the P2096 first, is there a link for this project I can check out?
I am very curious about the effects of your work on the designs, it promises to be very interesting. Insert photos as it will be ready
na problemy zawsze naprawa skóry |
P2096
Replaced eccentric valve sensor it was leaking oil. The P2096 is now off and on, Bank1 post cat, fuel too lean. Am I now to assume it is definitely the Oxygen sensor post cat?
328ix 6 speed
Help! Replaced Eccentric shaft sensor, and Bank1 oxygen sensor#2. Went 5 days no issues and no SES light, as soon as outside temp raised above 55/60 degrees, same issue. Rough idle at first stop light from exiting interstate.
What is it about the higher temp that is causing this rough idle? What do I attack next? Thanks |
