Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
Cars and Cappuccino
tdw28210's Avatar
Fuse Oversizing
So what are the potential negative impacts of putting a 15 amp fuse in a 5 amp slot for the diversity antenna in my '06 530 xi T? Can't afford the stealer's quote of $500 to $1500 diagnosis time to find the short.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 11-17-2012, 01:47 PM
The problem with over fusing is that you run the risk of melting the wiring, that in turn could cause any wires that are bundled also to melt and short or even a fire, in effect causing you many more problems than you have now.
Perhaps if you could describe the symptoms you are having more fully then we could attempt to help you isolate the problem.
Jack
Old 11-18-2012, 08:45 AM
