530i faulty error messages bad ground
Lots of error messages
transmission failure ABS failure dynamic drive failure seat belt not engaged and more Installed a new "Micro Power Module" in the trunk ( no water problems) Same error messages 2004 530i starts and drives Seems that the automatic transmission does not shift properly Is this a bad ground(s) problem Which ground connections are suspect ??? |
It could be, but before checking grounds you might want to ensure your battery and alternator are in top condition. A weak battery or alternator can cause the symptoms you've listed.
Administrator
Are you also getting a CEL ? If so, it may be a good idea to have the codes read - this will give you a lot of great info as to where to start troubleshooting.
Update
The problem was a bad voltage regulator on a Valeo alternator
The voltage output was at times much too high (17+ volts) Replaced the voltage regulator with an aftermarket model that had a much larger heat sink Just completed a 3,000 trip with no control module faults I suspect the Valeo voltage regulator has a weak design fault If it goes again, I would replace the alternator with a Bosch unit |
