'95 525i OBC stalk question
Just acquired a '95 525i in great running condition and I am getting up to speed with the OBC functions. Here is what is going on. The OBC display below the gauges does not activate when the stalk control is pressed in. However, it does come on when I change radio stations (indicates the new station briefly), when the check control button is depressed (check control OK), and when the car is first started indicating the service status. I drove another 5 series (530i) and the stalk did function the display.
Is this a matter of programming or possibly a bad switch? Any help would be appreciated. Thanks DT
sounds like a bad switch to me....dose the OBC work when you use the normal buttons on the dash?
1995 325i K&N air filter, clear corners and a lota fun! |
I did try the dash button and Check Control OK does come up. This car had a cell phone at one time but is now disconnected. I have heard this will cause a problem but I am not 100%. All of the plugs and cell phone jack are intact so I am wondering if I can jump them to complete the circuit. Any ideas?
Thanks DT |
